[postgis-devel] Re: sql files proliferation
Paul Ramsey pramsey at refractions.net
Sun Feb 29 16:48:35 PST 2004
Confusingly, I have yet to find *any* way to call cpp that works. In
fact, it does not appear to work the way the man page says it should...
it resolutely refuses to write an output file.
Still trying.
P.
On Sunday, February 29, 2004, at 02:43 PM, strk wrote:
> pramsey wrote:
>> OS/X cpp chokes for reasons I have yet to tease out. Probably not a
>> good sign for platform portability...
>> cpp: Too many arguments
> We could either find the right way to call CPP (autoconf?)
> or maybe opt for a perl script, since this is already required,
> to perform basic cpp (traditional) work.
> --strk;
>> On Saturday, February 28, 2004, at 06:52 AM, strk wrote:
>>> I've added an experimental source sql file and a corresponding rule
>>> in the Makefile. CPP call is with -traditional-cpp flag, which
>>> is nicer with multiline strings and '--' comments.
>>> If you can give it a try we can test for compatibility.
>>> Run make postgis_new.sql (it's not built by default) to
>>> get postgis_new.sql generated from postgis.sql.in.
>>> The source file (postgis.sql.in) is not optimized to use
>>> cpp features, it just a copy of all the files previously
>>> used wrapped in #if USE_VERSION == <ver> blocks.
>>> Runnign a diff between postgis.sql and postgis_new.sql should
>>> give you just comments, blank lines and the postgis_version()
>>> function with double quotes ('') instead of slash escaped (/')
>>> quote inside the SQL function.
>>> --strk;
>>> strk wrote:
>>>> pramsey wrote:
>>>>> I wonder if we can use cpp and simple #ifdef stuff to do the
>>>>> preprocessing. Would be nice.
>>>>> P.
>>>> I made some use of cpp with languages other then C.
>>>> The main problem is that cpp thinks #-lines are overlooked byt
>>>> the compilers. GNU cpp version accepts -P to omit linemarkers
>>>>        -P  Inhibit generation of linemarkers in the output from
>>>>            the preprocessor.  This might be useful when running
>>>>            the preprocessor on something that is not C code, and
>>>>            will be sent to a program which might be confused by
>>>>            the linemarkers.
>>>> ... but that could not be always the case.
>>>> Can people try that (or similar) to solve the linemark problem ?
>>>> --strk;
>>>>> strk wrote:
>>>>>> The postgis*sql* files are becoming a major part
>>>>>> of the distribution (as number of files).
>>>>>> What about having a single sql for each postgres version ?
>>>>>> Or - better - use some preprocessing to keep in common
>>>>>> things that are common and spilt things that need to be
>>>>>> splitted ?
>>>>>> I need to move geometry_column creation out of _common_
>>>>>> into each of version-specific files because for PG75 there
>>>>>> is no need of attrelid oid, varattnum int and stats histogram2d;
>>>>>> this already happended for schema support changes
>>>>>> (addGeometryColumn,
>>>>>> dropGeoemtryColumn, fix_geometry_columns) and is getting boring.
>>>>>> --strk;
>>>>>        __
>>>>>       | Paul Ramsey
>>>>>       | Refractions Research
>>>>>       | Email: pramsey at refractions.net
>>>>>       | Phone: (250) 885-0632
>>>>>       \_
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>       Paul Ramsey
      Paul Ramsey
