[postgis-devel] geos / postgis version
strk strk at keybit.net
Thu Jul 22 10:12:09 PDT 2004
Ok, geos::version() has been split in geos::geosversion()
and geos::jtsport().
Postgis postgis_geos_version() will report geos version only
(I don't think we need to know JTS equivalent...)
I won't make the postgis_scripts_version() function now, as
I think it requires a deeper though about how it is supposed
to be used... If we need it to detect an incongruency between
pl/pgsql,sql functions and library functionalities we need to
understand what makes an incongruency and what does not.
--strk;
On Thu, Jul 22, 2004 at 06:20:45PM +0200, strk wrote:
> I've added postgis_lib_version() and postgis_geos_version().
> Before proceeding it might be worth changing geos::version()
> output (and maybe name) to be able to get GEOS version only
> (and geos::jtsport() addition...).
> Any hint on proj4 version string extraction is appreciated
> (with back-compatibility in mind).
> NOTE that postgis_lib_version also reports micro version
> which is actually not used in library file name (this is
> built using postgresql rule, which do not take a micro version
> number). Remember to upgrade SO_MICRO_VERSION between releases.
> --strk;
> On Thu, Jul 22, 2004 at 08:24:59AM -0700, Paul Ramsey wrote:
> > I think it is wise, and you should look at one of the emails today,
> > which suggested reporting out versions of the libraries we are using
> > (geos,proj) in addition to whether we have them.
> > strk wrote:
> > >Current postgis_version() function is implemented as a pl/pgsql
> > >function. Sometimes people upgrade postgis library w/out upgrading
> > >pl/pgsql functions, and this is *sometimes* a problem.
> > >I think it would be useful to have the following informations
> > >retrivable:
> > >	postgis_scripts_version();	// pl/pgsql  function
> > >	postgis_lib_version();		// C function
> > >	postgis_geos_version();		// C function
> > >Our postgis_version() would then be a wrapper, retriving the above
> > >informations and warning user in case
> > >postgis_scripts_version() != postgis_lib_version()
> > >What do you think ?
> > >--strk;
> > >_______________________________________________
> > >postgis-devel mailing list
> > >postgis-devel at postgis.refractions.net
> > >http://postgis.refractions.net/mailman/listinfo/postgis-devel
