[postgis-devel] Patch: Make TestServer Compile
Markus Schaber
schabios at logi-track.com
Fri Jun 4 02:59:25 PDT 2004
The attached patch is needed to make PostGIS TestServer compile.
This problem was mentioned before by others, what's the way to go to get
it checked in?
Thanks,
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Index: TestServer.java
RCS file: /home/cvs/postgis/postgis/jdbc/examples/TestServer.java,v
retrieving revision 1.2
diff -u -r1.2 TestServer.java
--- TestServer.java 19 Apr 2002 15:14:17 -0000 1.2
+++ TestServer.java 4 Jun 2004 10:00:24 -0000
@@ -32,8 +32,8 @@
String url = "jdbc:postgresql://" + dbhost + ":" + dbport + "/" + dbname;
conn = DriverManager.getConnection(url, dbuser, dbpass);
System.out.println("Adding geometric type entries...");
- ((org.postgresql.Connection)conn).addDataType("geometry","org.postgis.PGgeometry");
- ((org.postgresql.Connection)conn).addDataType("box3d","org.postgis.PGbox3d");
+ ((org.postgresql.PGConnection)conn).addDataType("geometry","org.postgis.PGgeometry");
+ ((org.postgresql.PGConnection)conn).addDataType("box3d","org.postgis.PGbox3d");
Statement s = conn.createStatement();
System.out.println("Creating table with geometric types...");
//table might not yet exist
