[postgis-devel] DropGeometryTable
strk strk at keybit.net
Fri Jun 4 03:25:53 PDT 2004
On Tue, Jun 01, 2004 at 12:05:56PM -0700, Wood Brent wrote:
> I have a stored query called drop_geo_table which does a clean removal of the
> geometry_column entry & then the actual table.
> I think a similar built in function, such as DropGeometryTable() (which would
> call DropGeometryColmn(), then drop the table) or an argument to
> DropGeometryColumn() to drop the table after removing the record would be  a
> simple way to provide the functionality.
Current CVS has DropGeometryTable([<schema>], <table>).
It sounded as a good idea.
--strk;
