[postgis-devel] lwgeom parser robustness and niceness
strk strk at keybit.net
Mon Jun 7 08:37:17 PDT 2004
Carl, you were right, it was the error function ....
I've fixed it. Now you get ERRORs instead of traps.
Also, I've unleashed the parser to accept miXeD case.
A rimaning issue is about wheter to accept (MULTI)POINT(),
(MULTI)LINESTRING(), (MULTI)POLYGON(), GEOMETRYCOLLECTION()
as empty geometries... I think that would be nice, are there
comments ?
--strk;
On Mon, Jun 07, 2004 at 03:14:52PM +0200, strk wrote:
> On Mon, Jun 07, 2004 at 09:03:40AM -0400, Carl Anderson wrote:
> > strk wrote:
> > >I've been testing lwgeom stuff.
> > >I've found it fault on every 'unexpected' format.
> > >All these queries kill the backend:
> > >        -- EMPTY geoms
> > >        SELECT 'POINT()'::lwgeom;
> > >        SELECT 'MULTIPOINT()'::lwgeom;
> > >        SELECT 'LINESTRING()'::lwgeom;
> > >        SELECT 'MULTILINESTRING()'::lwgeom;
> > >        SELECT 'POLYGON()'::lwgeom;
> > >        SELECT 'MULTIPOLYGON()'::lwgeom;
> > >        SELECT 'GEOMETRYCOLLECTION()'::lwgeom;
> > >        -- NON geoms (a check for first letter is performed)
> > >        SELECT 'P()'::lwgeom
> > >        SELECT 'L()'::lwgeom
> > >        SELECT 'M()'::lwgeom
> > >        SELECT 'G()'::lwgeom
> > >        -- INVALID geoms
> > >        SELECT 'POINT(0 0 0 0 0)'::lwgeom;
> > >        SELECT 'LINESTRING(0 0)'::lwgeom;
> > >        SELECT 'POLYGON((0 0, 1 1))'::lwgeom;
> > >        SELECT 'POLYGON(0 0)'::lwgeom;
> > >        ... try your own ...
> > >        -- MIXED dimension geoms
> > >        SELECT 'MULTIPOINT(0 0 0, 0 0)'::lwgeom;
> > >        SELECT 'LINESTRING(0 0 0 0, 0 0 0)'::lwgeom;
> > >Also, I don't like this error message:
> > >	SELECT 'point(0 0)'::lwgeom;
> > >	ERROR:  couldnt determine if input lwgeom is WKB or WKT
> > >I think 1) it's clearly a WKT and 2) we could accept lower or mixed case
> > >lwgeoms, wouldn't it be acceptable in speed ?
> > >--strk;
> > If you edit the bison/lex files to include rules that cover the above
> > cases the abends stop.  Not that this is the corrent fix just evidence
> > that it is in bison/flex
> > such as in wktparse.y
> > from
> > a_point: point_2d | point_3d | point_4d;
> > to include a rule for POINT()
> > a_point: empty | point_2d | point_3d | point_4d;
> > I am not very good with bison/flex but
> > I suspect that the parser code is emitting a warning that is tripping
> > Postgres.  I have poked at the passed in error function But I think I
> > would need to RTFM first.
> I suspect unallocated memory access actually...
> Ralph, could you produce a simple test app parsing WKT from stdin
> and dumping WKT to stdout ?
> > btw
> > moving Makefile to
> > 	$(YACC) -vd -b wktparse -p lwg_parse_yy wktparse.y
> > causes it to produce wktparse..tab.c and wktparse.tab.h directly
> Before adding switches $(YACC) compatibilities should be checked.
> I belive postgresql guys to be aware of this, and they rename
> the output...
> --strk;
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
