[postgis-devel] Re: NULL geometries
David Blasby dblasby at refractions.net
Mon Jun 7 10:15:19 PDT 2004
I'm not sure why people are having problems (crashes) with geometries
like 'POINT()' - there are tests in the regression files that test
inputs like this.  I didnt have any crashes.
This is probably a problem with people's FLEX/BISON.  Thats why I put
the actual output file in CVS so everyone would have a common source in
stead of relying on everyones different version of flex/bison to work.
Its a bit ambigeous if the SFSQL spec supports things like "POINT()" or
"POINT(EMPTY)":
2.1.3 Point
A Point is a 0-dimensional geometry and represents a single location in
coordinate space. A Point has a xcoordinate
value and a y-coordinate value.
The boundary of a Point is the empty set.
2.1.3.1 Methods
X( ):Double —The x-coordinate value for this Point.
Y( ):Double —The y-coordinate value for this Point.
PostGIS supports empty geometries like:
lwgeom_reg=# select 'GEOMETRYCOLLECTION(EMPTY)'::geometry;
              geometry
  SRID=-1;GEOMETRYCOLLECTION(EMPTY)
(1 row)
lwgeom_reg=# select 'MULTIPOINT(EMPTY)'::geometry;
          geometry
  SRID=-1;MULTIPOINT(EMPTY)
(1 row)
PostGIS does NOT support geometries "POINT(EMPTY)" - only
GEOMETRYCOLLECTION and MULTI* geometries.  The actual representation is,
say, a MULTIPOINT with 0 geometries in it.
Currently, LWGEOM isnt supporting this - its should be simple addition
to handle it.
Things like "POINT(EMPTY)" maybe valid WKT, but I dont think they are
actually valid geometries.  NOTE: there is no WKB representation for
"POINT(EMPTY)".
dave
