[postgis-devel] lwgeom parser robustness and niceness
David Blasby dblasby at refractions.net
Mon Jun 7 10:21:42 PDT 2004
Markus Schaber wrote:
> On Mon, 7 Jun 2004 11:49:53 +0200
> strk <strk at keybit.net> wrote:
>>        -- INVALID geoms
>>        SELECT 'LINESTRING(0 0)'::lwgeom;
>>        SELECT 'POLYGON((0 0, 1 1))'::lwgeom;
>>        SELECT 'POLYGON(0 0)'::lwgeom;
> As I see those, I think it would be good to add a call to isvalid()
> after parsing a lightweight geometry so that only valid geometries can
> be written into the database.
We've had discussion on this before - the consensus was that people
didnt want this to happen automatically.
If you want your tables to only allow valid geometries, you can add a
constaint like this:
ALTER TABLE <table> ADD CONSTRAINT <name> CHECK (isvalid(the_geom));
dave
