[postgis-devel] lwg wkt parser kills postgres
strk strk at keybit.net
Tue Jun 8 01:21:20 PDT 2004
On Mon, Jun 07, 2004 at 11:39:45PM +0000, Carl Anderson wrote:
> >>On 06/07/2004 05:28:01 PM, David Blasby wrote:
> >>>strk wrote:
> >>>>bison-1.33 and bison-1.32
> >>>>Both keep killing the backend.
> >>>>test=# select 'POINT()'::lwgeom::geometry;
> >>>>server closed the connection unexpectedly
> >>>>What about flex Dave ?
> >>>$ flex --version
> >>>flex version 2.5.4
> >>this patch will give a hint
> >>with it all regression tests complete correctly for me.
> >Looks like your lex/yacc were giving you an extra error() function
> >that was being incorrectly called instead of the "real" one.
> Excuse my ignorance but grepping for "error\(" shows only the instance
> in lwgparse.c
> ../../../src/Makefile.global
It could be defined in some compiled library.
> another hint
> edit
> set CFLAGS to not have -O2
> ie from
>  CFLAGS = -O2 -fno-strict-aliasing
> to
>  CFLAGS = -fno-strict-aliasing
> and use EXACTLY what is in CVS
Don't think its nice to require this.
Your 'static' specifier works for me as well, and it
seems to be the right thing.
Committed.
--strk;
> >dave
> >_______________________________________________
> >postgis-devel mailing list
> >postgis-devel at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-devel
