[postgis-devel] lwgeom: regress tests
Carl Anderson carl.anderson at co.fulton.ga.us
Tue Jun 8 05:40:18 PDT 2004
strk wrote:
> On Tue, Jun 08, 2004 at 11:13:33AM +0000, Carl Anderson wrote:
>>On 06/08/2004 05:05:23 AM, strk wrote:
>>>All regress tests run with no problems for me.
>>>Just a note. I do not have a 'postgres' user, so I had
>>>to remove the \c line on top of regres_lots_of_points.sql
>>>If this is not a problem I'd remove the 'You are now connected as...'
>>>line from the expected result.
>>>--strk;
>>Another problem for me was on createdb
>>createdb -T template0 lwgeom_reg
>>will derive from template0 not the usual template1.
>>template0 is always clean whilst template1 may have localizations
>>tsearch, plpgsql, postgis, ...
> plpgsql and postgis are loaded by regression tests.
> did localizations or other thikngs make regress fail ?
> --strk;
plpgsql is in my template1
it causes a message to stderr but the normal output still works ok and
regression tests pass.
My point is that unless you start with template0 you are not starting
from a known quantity.
C.
>>C.
>>>_______________________________________________
>>>postgis-devel mailing list
>>>postgis-devel at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
Carl Anderson
GIS Manager, Fulton County E&CD
404.730.8026
