[postgis-devel] 7.5 GiST Patch
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Fri Jun 18 03:06:58 PDT 2004
Hi Paul,
No-one reported any problems with the 7.5 GiST patch applied to my Win32
build and so strk has applied a modified version of the patch to CVS. I
can confirm that PostGIS compiles fine for me under Win32 7.5 and also
Linux 7.5 - the only problems I've experienced are that under Win32 a
'make install' doesn't work with the shp2pgsql/pgsql2shp executables and
I have to manually compile postgis_geos_wrapper.cpp as per my post at
http://postgis.refractions.net/pipermail/postgis-users/2004-June/004960.
html if I want GEOS support. I haven't yet tried building and testing
with GEOS under Linux. I can also report that I haven't found any
problems with building indices under either platform.
It would be useful if Dave gets a moment to apply the 7.5 GiST patch to
the LWGEOM GiST functions - it should only take a couple of minutes.....
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Paul Ramsey
> Sent: 17 June 2004 18:55
> To: PostGIS Development Discussion
> Subject: [postgis-devel] 7.5 GiST Patch
> Mark,
> Did you get any love from HACKERS on your GiST patch for 7.5? Paul
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> postgis-devel mailing list postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
