[postgis-devel] 7.5 GiST Patch
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Jun 18 10:32:06 PDT 2004
Hi Dave,
I only submitted a patch for postgis_gist_72.c - it didn't include the
changes for lwgeom/lwgeom_gist.c. If you load the two files side by side
and search for USE_VERSION in postgis_gist_72.c you'll be able to see
the differences - it's the entryvec structure that has changed.
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of David Blasby
> Sent: 18 June 2004 17:22
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] 7.5 GiST Patch
> Mark Cave-Ayland wrote:
> > It would be useful if Dave gets a moment to apply the 7.5
> GiST patch
> > to the LWGEOM GiST functions - it should only take a couple of
> > minutes.....
> I thought I had already applied the patch a while ago.  Could
> you give a
> very brief summary and re-send me the patch?
> dave
> postgis-devel mailing list postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
