[postgis-devel] SRID in GiST patch (implementation of GEOMETRYKEY) for PG > 7.2
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Sat Jun 26 06:03:05 PDT 2004
Hi guys,
I've been having a look at Corey's problem with SRID mismatches not
being identified when using indexable operators (see
http://postgis.refractions.net/pipermail/postgis-users/2004-May/004939.h
tml and
http://postgis.refractions.net/pipermail/postgis-users/2004-May/004946.h
tml) and identified the problem. The RECHECK clause was failing because
the query region and the data region did not overlap, and so the query
returned no rows. And because the query returned no rows, the RECHECK
didn't have any geometries to detect a SRID mismatch :)
So it looks as if the only way to pick up on these errors is to bite the
bullet and put the SRID in the index. Please find the enclosed patch
against CVS which will solve this issue by implementing the GEOMETRYKEY
structure (minus the length field) as was used in the original 7.1 index
code. I don't intend to apply this at the moment, I'd like to see what
other developers think about this since it is quite a large change.
Once this patch is applied, you'll need to enter the following into your
PostGIS database:
CREATE OR REPLACE FUNCTION geometrykey_in(cstring)
	RETURNS geometrykey
	AS '$libdir/libpostgis.dll'
	LANGUAGE 'C' WITH (isstrict);
CREATE OR REPLACE FUNCTION geometrykey_out(geometrykey)
	RETURNS cstring
CREATE TYPE geometrykey (
	alignment = double,
	internallength = 36,
	input = geometrykey_in,
	output = geometrykey_out
UPDATE pg_opclass
	SET opckeytype = (select oid from pg_type where typname =
'geometrykey')
	WHERE opcname = 'gist_geometry_ops';
...and now recreate any geometry GiST indices you have. You should now
find that *ALL* queries where the SRID mismatches will throw a SRID
mismatch error when using the index.
The good parts:
	- We finally detect *ALL* SRID mismatches when using the index
	- We can lose the RECHECK operator from the op class definitions
again
The bad parts:
	- Each entry in the index requires another 4 bytes to store the
SRID,
	so the overall size of the index is bigger
	- The GiST code requires that a dummy "geometrykey" type exists
If anyone feels like experimenting with reducing the doubles down to
floats a la LWGEOM then please do, as that would make a very good case
for applying the patch as then index sizes will get smaller - oh, and
let me know if I missed any memory leaks too :)
Comments anyone?
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20040626/6114ded1/attachment.obj>
