[postgis-devel] Debugging my rounding function
David Blasby
dblasby at refractions.net
Wed Jun 30 09:10:55 PDT 2004
Gino Lucrezi wrote:
> Unfortunately, PostgreSQL crashes as soon as I call my function, before even
> entering it.
> < PG_FUNCTION_INFO_V1(GeomRound);
> < Datum geom_round(PG_FUNCTION_ARGS)
You have "GeomRound" in the top line, but "geom_round" in the 2nd line;
they need to be the same.
You're getting a crash because the "PG_FUNCTION_INFO_V1" macro isnt
properly setting up the function so Postgresql can call it (and give it
arguments).
When you get to the line:
"GEOMETRY *geom = (GEOMETRY *) PG_DETOAST_DATUM(PG_GETARG_DATUM(0));"
it crashes because its trying to access arguments that havent actually
been sent to the function.
dave
