[postgis-devel] Re: geometry stats
David Blasby dblasby at refractions.net
Mon Mar 1 12:32:49 PST 2004
I looked at the way the new (7.4) gist_rtree works.  Its changed since
7.2.  In fact, its almost morphed itself back to what it looked like in 7.1.
Basically, they use different strategies based on where they are in the
search - either at internal nodes in the tree or in leafs.  GiST trees
are a little different than normal binary search trees (for lots of
reasons, but I want to emphasis one).  Here's the last portion of a tree.
       'J'
  Ant     Spider
The two leafs ("Ant" and "Spider") would represent actual database rows.
  Unlike most binary trees, the internal nodes are *not* actual database
rows.  Here "J" is 1/2 way between 'Ant' and 'Spider'.
In the Rtree GiST, the internal node is a BOX that contain all the boxes
below them in the tree.
The 7.4 codes uses this for *internal* BOXes (unioned boxes):
  switch (strategy)
         case RTLeftStrategyNumber:
         case RTOverLeftStrategyNumber:
             retval = DatumGetBool(DirectFunctionCall2(box_overleft,
PointerGetDatum(key), PointerGetDatum(query)));
             break;
         case RTOverlapStrategyNumber:
             retval = DatumGetBool(DirectFunctionCall2(box_overlap,
             break;
         case RTOverRightStrategyNumber:
         case RTRightStrategyNumber:
             retval = DatumGetBool(DirectFunctionCall2(box_right,
             break;
         case RTSameStrategyNumber:
         case RTContainsStrategyNumber:
             retval = DatumGetBool(DirectFunctionCall2(box_contain,
             break;
         case RTContainedByStrategyNumber:
             break;
         default:
             retval = FALSE;
and this (more exact) for leafs (ie. real geometries):
    switch (strategy)
             retval = DatumGetBool(DirectFunctionCall2(box_left,
             break;
             break;
             break;
             retval = DatumGetBool(DirectFunctionCall2(box_overright,
             break;
             break;
             retval = DatumGetBool(DirectFunctionCall2(box_same,
             break;
             break;
             retval = DatumGetBool(DirectFunctionCall2(box_contained,
             break;
         default:
             retval = FALSE;
I'm not sure why they also have a RECHECK, unless the polygon type's
actual contains() function checks for true containment.
So;
1. There shouldnt be anything wrong with the && operator.  If anyone's
ever seen an example of the index and seq scan returning different
results, SEND ME THE TEST.  I'm going to write a simple program to test
the current one (as I outlined earlier today).
2. We can fix the '@~'-like operators by either (a) adding RECHECK to
the definition or (b) adding the leaf consistent function (as in the
rtree_gist 7.4 implementation shown above) or (c) both.
dave
