[postgis-devel] postgis_new.sql
strk strk at keybit.net
Mon Mar 22 00:19:55 PST 2004
On Fri, Mar 19, 2004 at 01:04:35PM -0800, David Blasby wrote:
(cuts)
> I havent looked at postgis_new.sql.
> dave
I've put postgis_new.sql build rule in the default build list.
Please check if it works for you. It is an attempt at producing
the sql file using cpp.
--stkr;
