[postgis-devel] Should geomunion() compress output geometry type ?
Carl Anderson
carl.anderson at co.fulton.ga.us
Tue Mar 23 06:58:27 PST 2004
strk wrote:
> Current geomunion() implementation issues a compressType()
> call as the final step. The compressType() function will
> make Multi*-typed geometries with one element become
> Single*-typed.
> This might not be what you need.
> The bad thing is that you end up fighting against table constraints.
> (you need a multipolygon, no matter how many resulting polygons are
> in the risult geometry)
> What about making the compressType() function available
> as a compress(GEOMETRY) function ?
> Or - maybe - introduce a function to make Single-typed geoms Multi-typed ?
There is a bigger problem of geometry type casting up and down and
filtering that needs help.
while geomunion() can return a lesser subtype (Polygon vs MultiPolygon)
difference(), and symdifference() can return ANY geometry type
Polygon / Polygon can return (properly) Point, LineString,
Polygon, GeometryCollection or the Multi form of each.
If I want of silently ignore the Line and Point return types as well as
extract Polygons from Collections I would need a
geometry_filter(geometry,'type') function that would
downcast / upcast geometry types into a requested geometry type as well
as filter types that cannot be coalesced into the desired form.
something like
new_geom = geometry_filter(geom_union(a.geom1, b.geom2),'MULTIPOLYGON');
or also upcast linestrings that are closed
new_geom = geometry_filter(interiorringn(a.geom,1),'POLYGON')
A crude example of such an function (implemented in plpgsql) is attached
Carl Anderson
GIS Manager, Fulton County E&CD
404.730.8026
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20040323/bab01c5c/attachment.ksh>
