[postgis-devel] postgis.sql.in
Paul Ramsey pramsey at refractions.net
Sat Mar 27 13:00:34 PST 2004
Definately tried it manually, which is how I found which commandline
parameters were fussing it up. I have not tried an alternate shell yet,
but I don't know exactly how that will help... if our build only works
on bash, that is kind of a limiting...
P
On Friday, March 26, 2004, at 10:54 PM, strk wrote:
> On Fri, Mar 26, 2004 at 12:59:10PM -0800, Paul Ramsey wrote:
>> I still cannot use the cpp version in OS/X 10.2, unfortunately. The
>> stdout fix helped one major problem, but the another problem remains.
>> I
>> simply cannot get the $libdir variable to go into the file, and I
>> cannot
>> get the '' marks to go into the file. cpp generally complains that it
>> has the wrong number of arguments on the command line. I tried every
>> combination I could think of... it was/is cpp 2.96.
>> Paul
> It works for me with:
>  GNU CPP version 2.95.4 20011002 (Debian prerelease) (i386 Linux/ELF)
> Did you try manually running it (without the intervention of make) ?
> Also try changing the shell.
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
