[postgis-devel] postgis.sql.in
strk strk at keybit.net
Mon Mar 29 02:44:40 PST 2004
I've modified postgis.sql.in and Makefile to use both sed for
keyworkds substitution and cpp for conditional blocks.
Can you try this version ?
--strk;
On Mon, Mar 29, 2004 at 11:06:56AM +0200, strk wrote:
> On Sat, Mar 27, 2004 at 01:00:34PM -0800, Paul Ramsey wrote:
> > Definately tried it manually, which is how I found which commandline
> > parameters were fussing it up. I have not tried an alternate shell yet,
> > but I don't know exactly how that will help... if our build only works
> > on bash, that is kind of a limiting...
> > P
> As an alternative we could keep using sed for keywords substitution
> and cpp for conditional blocks. I'll try that and let you know.
> --strk;
> > On Friday, March 26, 2004, at 10:54 PM, strk wrote:
> > > On Fri, Mar 26, 2004 at 12:59:10PM -0800, Paul Ramsey wrote:
> > >> I still cannot use the cpp version in OS/X 10.2, unfortunately. The
> > >> stdout fix helped one major problem, but the another problem remains.
> > >> I
> > >> simply cannot get the $libdir variable to go into the file, and I
> > >> cannot
> > >> get the '' marks to go into the file. cpp generally complains that it
> > >> has the wrong number of arguments on the command line. I tried every
> > >> combination I could think of... it was/is cpp 2.96.
> > >> Paul
> > > It works for me with:
> > >  GNU CPP version 2.95.4 20011002 (Debian prerelease) (i386 Linux/ELF)
> > > Did you try manually running it (without the intervention of make) ?
> > > Also try changing the shell.
> > > --strk;
> > > _______________________________________________
> > > postgis-devel mailing list
> > > postgis-devel at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> >       Paul Ramsey
> >       Refractions Research
> >       Email: pramsey at refractions.net
> >       Phone: (250) 885-0632
