[postgis-devel] postgis.sql.in
Paul Ramsey
pramsey at refractions.net
Mon Mar 29 09:45:52 PST 2004
That works :)
On Monday, March 29, 2004, at 02:44 AM, strk wrote:
> I've modified postgis.sql.in and Makefile to use both sed for
> keyworkds substitution and cpp for conditional blocks.
> Can you try this version ?
> --strk;
> On Mon, Mar 29, 2004 at 11:06:56AM +0200, strk wrote:
>> On Sat, Mar 27, 2004 at 01:00:34PM -0800, Paul Ramsey wrote:
>>> Definately tried it manually, which is how I found which commandline
>>> parameters were fussing it up. I have not tried an alternate shell
>>> yet,
>>> but I don't know exactly how that will help... if our build only
>>> works
>>> on bash, that is kind of a limiting...
>>> P
>> As an alternative we could keep using sed for keywords substitution
>> and cpp for conditional blocks. I'll try that and let you know.
>> --strk;
>>> On Friday, March 26, 2004, at 10:54 PM, strk wrote:
>>>> On Fri, Mar 26, 2004 at 12:59:10PM -0800, Paul Ramsey wrote:
>>>>> I still cannot use the cpp version in OS/X 10.2, unfortunately. The
>>>>> stdout fix helped one major problem, but the another problem
>>>>> remains.
>>>>> I
>>>>> simply cannot get the $libdir variable to go into the file, and I
>>>>> cannot
>>>>> get the '' marks to go into the file. cpp generally complains that
>>>>> it
>>>>> has the wrong number of arguments on the command line. I tried
>>>>> every
>>>>> combination I could think of... it was/is cpp 2.96.
>>>>> Paul
>>>> It works for me with:
>>>> GNU CPP version 2.95.4 20011002 (Debian prerelease) (i386
>>>> Linux/ELF)
>>>> Did you try manually running it (without the intervention of make) ?
>>>> Also try changing the shell.
>>>> --strk;
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>> Paul Ramsey
>>> Refractions Research
>>> Email: pramsey at refractions.net
>>> Phone: (250) 885-0632
Paul Ramsey
