[postgis-devel] Re: [postgis-users] trying to make
strk at refractions.net strk at refractions.net
Mon Nov 22 13:35:23 PST 2004
try this:
postgis/loader$ make CFLAGS="-lssl"
--strk;
On Mon, Nov 22, 2004 at 04:21:07PM -0500, János wrote:
> Looking for openssl it gives two locations:
> Janos:/Volumes/Data/Downloads/postgresql-7.4.6/contrib/postgis-0.9.0
> janos$ sudo find / -name openssl -print
> Password:
> /usr/bin/openssl
> /usr/include/openssl
> I added --with-openssl=/usr/bin/openssl to the ./confog of Postgresql
> and eliminated --with-pam, and I still get these - somewhat shorter -
> messages:
> janos$ sudo make
> ./geos_version.sh /usr/local > postgis_geos_version.h
> make -C loader
> gcc -no-cpp-precomp -g -I.. -I. -I../../../src/interfaces/libpq -O2
> -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-declarations
> -DFRONTEND -DSYSCONFDIR='"/Volums/Apps/pgsql/etc"' -DUSE_VERSION=73
> shpopen.o dbfopen.o getopt.o pgsql2shp.o
> -L../../../src/interfaces/libpq -lpq -L../../../src/port   -o pgsql2shp
> ld: Undefined symbols:
> _SSL_pending
> _BIO_free
> _BIO_new_mem_buf
> _DH_check
> _DH_generate_parameters
> _DH_size
> _ERR_get_error
> _ERR_reason_error_string
> _EVP_PKEY_free
> _PEM_read_DHparams
> _PEM_read_PrivateKey
> _PEM_read_X509
> _PEM_read_bio_DHparams
> _SSL_CTX_ctrl
> _SSL_CTX_free
> _SSL_CTX_load_verify_locations
> _SSL_CTX_new
> _SSL_CTX_set_tmp_dh_callback
> _SSL_CTX_set_verify
> _SSL_CTX_set_verify_depth
> _SSL_connect
> _SSL_free
> _SSL_get_error
> _SSL_get_ex_data
> _SSL_get_peer_certificate
> _SSL_library_init
> _SSL_load_error_strings
> _SSL_new
> _SSL_read
> _SSL_set_ex_data
> _SSL_set_fd
> _SSL_shutdown
> _SSL_write
> _TLSv1_method
> _X509_NAME_get_text_by_NID
> _X509_NAME_oneline
> _X509_check_private_key
> _X509_free
> _X509_get_subject_name
> make[1]: *** [pgsql2shp] Error 1
> make: *** [loaderdumper] Error 2
> should I do --with-openssl=/usr/include/openssl  or just forget about
> ssl for the time being ?
> Thanks ahead,
> János
> On Nov 22, 2004, at 3:28 PM, strk at refractions.net wrote:
> >Could it be you compiled postgresql with SSL support ?
> >In that case I think you need to add appropriate linkage to
> >that library.
> >--strk;
> >On Mon, Nov 22, 2004 at 03:20:05PM -0500, János wrote:
> >>I untared postgis-0.9.0 into the contrib directory of the Postgresql
> >>7.4.6 source.  This is what I get when I run sudo make:
> >>janos$ sudo make
> >>Password:
> >>gcc -no-cpp-precomp -O2 -fno-strict-aliasing -Wall
> >>-Wmissing-declarations -g -fexceptions  -I. -DFRONTEND
> >>-DSYSCONFDIR='"/Volums/Apps/pgsql/etc"'  -DUSE_VERSION=74
> >>-DPOSTGIS_LIB_VERSION='"0.9.0"' -DPOSTGIS_SCRIPTS_VERSION='"0.0.1"'
> >>-I/usr/local/include -DUSE_GEOS -I/usr/local/include -DUSE_PROJ
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_debug.o
> >>postgis_debug.c
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_ops.o postgis_ops.c
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_fn.o postgis_fn.c
> >>postgis_fn.c:3198: warning: no previous prototype for
> >>`postgis_scripts_released'
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_inout.o
> >>postgis_inout.c
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_proj.o postgis_proj.c
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_chip.o postgis_chip.c
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_transform.o
> >>postgis_transform.c
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_svg.o postgis_svg.c
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_gist_72.o
> >>postgis_gist_72.c
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_estimate.o
> >>postgis_estimate.c
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_geos.o postgis_geos.c
> >>postgis_geos.c:317: warning: `resize_ptrArrayType' defined but not
> >>used
> >>g++ -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
> >>-I/usr/local/include -DUSE_GEOS -I/usr/local/include -DUSE_PROJ  -fPIC
> >>-I../../src/include   -c -o postgis_geos_wrapper.o
> >>postgis_geos_wrapper.cpp
> >>cc1plus: warning: "-Wmissing-declarations" is valid for C/ObjC but not
> >>for C++
> >>-DUSE_STATS  -I../../src/include   -c -o postgis_algo.o postgis_algo.c
> >>ar crs libpostgis.a `lorder postgis_debug.o postgis_ops.o postgis_fn.o
> >>postgis_inout.o postgis_proj.o postgis_chip.o postgis_transform.o
> >>postgis_svg.o postgis_gist_72.o postgis_estimate.o postgis_geos.o
> >>postgis_geos_wrapper.o postgis_algo.o | tsort`
> >>tsort: cycle in data
> >>tsort: postgis_geos.o
> >>tsort: postgis_geos_wrapper.o
> >>tsort: postgis_fn.o
> >>tsort: postgis_inout.o
> >>ranlib libpostgis.a
> >>-DUSE_STATS  -bundle postgis_debug.o postgis_ops.o postgis_fn.o
> >>postgis_geos_wrapper.o postgis_algo.o -L../../src/port
> >>-L../../src/port
> >> -lstdc++ -L/usr/local/lib -lgeos -L/usr/local/lib -lproj
> >>-bundle_loader ../../src/backend/postgres   -o libpostgis.so.0.9
> >>ld: warning multiple definitions of symbol _translate
> >>postgis_fn.o definition of _translate in section (__TEXT,__text)
> >>../../src/backend/postgres definition of _translate
> >>rm -f libpostgis.so.0
> >>ln -s libpostgis.so.0.9 libpostgis.so.0
> >>rm -f libpostgis.so
> >>cpp -P -traditional-cpp -DUSE_VERSION=74 postgis.sql.in | sed -e
> >>'s:@MODULE_FILENAME@:\$libdir/libpostgis.so.0.9:g;s:@POSTGIS_VERSION@:
> >>0.9 USE_GEOS=1 USE_PROJ=1
> >>USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.0.1:g' > postgis.sql
> >>perl create_undef.pl postgis.sql 74 > postgis_undef.sql
> >>make -C loader
> >>-I../../../src/include   -c -o shpopen.o shpopen.c
> >>shpopen.c:176: warning: `rcsid' defined but not used
> >>-I../../../src/include   -c -o dbfopen.o dbfopen.c
> >>dbfopen.c:200: warning: `rcsid' defined but not used
> >>-I../../../src/include   -c -o getopt.o getopt.c
> >>getopt.c:115: warning: conflicting types for built-in function
> >>`strncmp'
> >>getopt.c:602: warning: no previous prototype for `getopt'
> >>-I../../../src/include   -c -o shp2pgsql.o shp2pgsql.c
> >>shpopen.o dbfopen.o getopt.o shp2pgsql.o -L../../../src/port   -o
> >>shp2pgsql
> >>-I../../../src/include   -c -o pgsql2shp.o pgsql2shp.c
> >>pgsql2shp.c: In function `parse_commandline':
> >>pgsql2shp.c:2297: warning: implicit declaration of function `getopt'
> >>pgsql2shp
> >>_SSL_pending
> >>_BIO_free
> >>_BIO_new_mem_buf
> >>_DH_check
> >>_DH_size
> >>_ERR_get_error
> >>_EVP_PKEY_free
> >>_PEM_read_DHparams
> >>_PEM_read_X509
> >>_SSL_CTX_ctrl
> >>_SSL_CTX_free
> >>_SSL_CTX_new
> >>_SSL_CTX_set_verify
> >>_SSL_connect
> >>_SSL_free
> >>_SSL_get_error
> >>_SSL_get_ex_data
> >>_SSL_library_init
> >>_SSL_new
> >>_SSL_read
> >>_SSL_set_ex_data
> >>_SSL_set_fd
> >>_SSL_shutdown
> >>_SSL_write
> >>_TLSv1_method
> >>_X509_NAME_oneline
> >>_X509_free
> >>What is wrong here ?
> >>Thanks ahead,
> >>János
> >>``Our enemies are innovative and resourceful, and so are we. They
> >>never
> >>stop thinking about new ways to harm our country and our people, and
> >>neither do we.''       -- George W. Bush
> >>_______________________________________________
> >>postgis-users mailing list
> >>postgis-users at postgis.refractions.net
> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
> We plan to reset the system twice tomorrow which improves performance
> until the problem reoccurs.
> --ITS Communication
