[postgis-devel] postgis-1.0: regression tests
strk at refractions.net strk at refractions.net
Fri Nov 26 07:50:11 PST 2004
I've been cleaning up and running some of the available
regression tests. Here is a report, if you have any concern
about the modification please tell me.
- Mixed-dimensioned geometries are no longer supported
  (previous behaviour was to fill Z with a 0 value)
  [ updated to use new behaviour ]
- geometry_same operator (=~) now requires all dimensions equality
  Previously only x/y were checked
- geometry_same operator (=~) now requires geom type equality
  Previous behaviour:
     GEOMETRYCOLLECTION(POINT(0 1), POINT(2 3)) =~  MULTIPOINT(0 1,2 3)
- numb_sub_geometries does not exist anymore
  [updated to use numgeometries]
- truly_inside does not exist anymore
  [updated to use within]
--strk;
