[postgis-devel] building jdbc against 8.0 jdbc driver fails
strk at refractions.net strk at refractions.net
Wed Oct 6 01:02:13 PDT 2004
On Wed, Oct 06, 2004 at 02:36:06AM -0500, Kris Jurka wrote:
> On Wed, 6 Oct 2004 strk at refractions.net wrote:
> > I've backported the fix to the 0_9 branch.
> > I think it's time for 0.9.1, as postgresql-8.0.0 support
> > is broken with 0.9.0.
> Well the cvs pgis_0_9_0 branch isn't in great shape.  Aside from the
> obvious flex and SPI_cursor_open fixes I sent in, the lwgeom directory
> fails to compile in the USE_GEOS=0 case.
> I understand not having 8.0 support as that's new and all, but it
> frightens me a little that your "stable" branch does not even compile.
Kris, it's still a CVS snapshot, not a release.
Anyway:
The 'lwgeom' directory in the pgis_0_9_0 branch is not maintaned.
The 'hwgeom' directory in the HEAD branch is not maintaned.
LWGEOM is in the HEAD
HWGEOM is in pgis_0_9_0
Each other couterparts are still in the repository for reference,
not for builds.
Did 'make' in the source root give you problems ?
--strk;
> Kris Jurka
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
