[postgis-devel] collect() updated
strk at refractions.net strk at refractions.net
Mon Oct 11 03:34:17 PDT 2004
I've fixed the collect() aggregate so that it keeps input geometries
structure.
The function returns a GEOMETRYCOLLECTION if:
	any multi type is found in input
	OR
	different single types are found in input
Alternatively it can return a MULTI if:
	all input is SINGLE typed
	AND
	all input has the same type
The function *never* returns a single type (ie. POINT=>MULTIPOINT).
You can use force_multi() to obtain the MULTI version.
You can use force_collection() to obtain the COLLECTION version.
The memcollect() function has been obsoleted (does not actually save
much memory).
--strk;
