[postgis-devel] 0.9.1, LWGEOM/HWGEOM, branches
Markus Schaber schabios at logi-track.com
Mon Oct 11 08:08:03 PDT 2004
Hi, Strk,
On Wed, 6 Oct 2004 10:16:36 +0200
strk at refractions.net wrote:
> A proposal to avoid confusion:
>  - CVS pgis_0_9_9 branch:
>    o *drop* LWGEOM
>  - CVS HEAD branch:
>    o *drop* HWGEOM
>  - Release postgis-0.9.1:
>    o sync support for PostgreSQL 8.0.0 (beta3)
> Comments ?
As the upgrade to PostgreSQL seems to enforce a dump/restore - will
those restores work when postgis is updated at the same time?
I recently had some problems when restoring dumps containing postgis
data when the postgis version changed inbetween (including the problem
that the 0.8.so could not be found when there actually was a 0.9.so).
Generally, a safe and easy way to migrate between postgis versions would
be appreciable.
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
