[postgis-devel] PG_NARGS not defined in fmgr.h < 7.3
Sébastien NICAISE
snicaise at iciatechnologies.com
Thu Oct 21 10:16:14 PDT 2004
http://postgis.refractions.net/pipermail/postgis-users/2003-August/002945.html
>> PG_NARGS is not defined in fmgr.h < 7.3
>> It is used with no check in postgis_inout.c (multiple times)
>> All checks can be substituted with the macro
>> PG_ARGISNULL() available also on the older pgres versions.
Here is the patch for file : lwgeom_inout.c lwgeom_ogc.c postgis_svg.c
Sebastien N.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20041021/4acc9a53/attachment.ksh>
