[postgis-devel] Re: [postgis-users] Possible index stats problem?
strk at refractions.net strk at refractions.net
Mon Sep 13 23:38:40 PDT 2004
> You got better results with lower statistics target.
> Anyway, in both cases the estimated number or rows returned was
> lower then the actual, so that is not the reason why the planner
> choosed Sequencial scan.
> The wrong estimation is due to a wrong estimate on the cost of
> using the index as contrary to execute a sequencial scan.
> As you can see the Sequencial scan has a cost 0.00..321.90
> while the Index scan has an higher cost of 0.00..475.56.
> This does not reflect reality as Sequencial scan took 48125+ms
> while Index scan took 6718+ms, so cost estimation was not correct.
Mark, I think I've found the problem, but I'd like to hear your
opinion as a pgsql hacker. A 'TODO'-labeled piece of code in
postgis_estimate.c reminded me about this. The stawidth field
of the VacAttrStats structure to be filled by compute_geometry_stats()
is currently filled by average width of sample geometries, but
given cost estimations results it might need average width of index
keys, does it sound correct ?
In the reported case postgresql is considering cost of index scan
higher then it is, so I think this is the problem.
What do you think ?
--strk;
