[postgis-devel] gist broken on PG 8.0
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Sep 17 02:50:50 PDT 2004
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: 16 September 2004 16:46
> To: postgis-devel at postgis.refractions.net
> Subject: [postgis-devel] gist broken on PG 8.0
> I've been spending a good amount of time trying to debug
> gist indexing for LWGEOM. I now discovered the bug
> also show with HWGEOM (current CVS code - should be 0.9).
> Does anyone experience segfaults with PG8.0.0beta2 and
> postgis 0.9 / head CVS branches ?
> Adding hooks in postgresql gist code I found out that
> gistchose() get a Page as argument which has a
> maxoffsetnumber == 0, which makes code around gist.c:1477
> loop forever (up to memory fault).
> Any help ?
> --strk;
Hi strk,
I've just done a fresh install with PG 8.0b2 and PostGIS 0.9. I loaded
in an 8,000 geometry shapefile, build an GiST index, and tried a few
queries without any problems. I also ran through the test_estimation.pl
several times, and again didn't experience any crashes.
Kind regards,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
