[postgis-devel] bug in simplify a polygon
Fu Chen fchen at ne.rsgs.ac.cn
Mon Sep 20 19:46:27 PDT 2004
But simple polygon seems ok in simplify procedure, not all the polygon get such weird result :)
I think maybe you can  create a row by this WTK string and test it.
I send the string in the text file in this file.
If you like the shp file, I can also send it to you.
Thanks!
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-bounces at postgis.refractions.net]On Behalf Of strk at refractions.net
Sent: Sunday, September 19, 2004 12:41 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] bug in simplify a polygon
My brain faulted trying to read the message...
can you provide a simpler example ?
--strk;
On Sat, Sep 18, 2004 at 12:48:36PM +0800, Fu Chen wrote:
> Hi!
> I find there must be some bugs in the function to simplify a polygon. some polygon get weird result after simplify.
> here is the example
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20040921/33b4f6dd/attachment.txt>
