[postgis-devel] loader incompatibility
strk at refractions.net strk at refractions.net
Tue Apr 5 07:52:47 PDT 2005
On Tue, Apr 05, 2005 at 04:30:16PM +0200, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net schrieb:
> > (Markus: sorry about patches requiring rework)
> No problem :-)
> I just attach a reworked patch that should apply against current CVS. I
> added updates for manpage and postgis manual XML file, and removed the
> transaction change (moving of "BEGIN;" output).
> If you are still in favour of applying this changes before release, I
> can commit them :-)
I need to look closer at them, as I told you I see too many arguments
to the load_data function. I guess it could take NO args.
--strk;
> Markus
> Index: doc/postgis.xml
> RCS file: /home/cvs/postgis/postgis/doc/postgis.xml,v
> retrieving revision 1.135
> diff -u -r1.135 postgis.xml
> --- doc/postgis.xml	5 Apr 2005 08:00:07 -0000	1.135
> +++ doc/postgis.xml	5 Apr 2005 14:17:09 -0000
> @@ -1283,13 +1283,23 @@
>            </varlistentry>
>            <varlistentry>
> +            <term>-p</term>
> +            <listitem>
> +              <para>Only produces the table creation SQL code, without adding
> +              any actual data. This can be used if you need to completely
> +              separate the table creation and data loading steps.</para>
> +            </listitem>
> +          </varlistentry>
> +          <varlistentry>
>              <term>-D</term>
>              <listitem>
> -              <para>Creates a new table and populates it from the Shape file.
> -              This uses the PostgreSQL "dump" format for the output data and
> -              is much faster to load than the default "insert" SQL format. Use
> -              this for very large data sets.</para>
> +              <para>Use the PostgreSQL "dump" format for the output data. This
> +              can be combined with -a, -c and -d. It is much faster to load
> +              than the default "insert" SQL format. Use this for very large data
> +              sets.</para>
>              </listitem>
>            </varlistentry>
> @@ -1334,6 +1344,8 @@
>          </variablelist>
> +        <para>Note that -a, -c, -d and -p are mutually exclusive.</para>
>          <para>An example session using the loader to create an input file and
>          uploading it might look like this:</para>
> Index: doc/man/shp2pgsql.1
> RCS file: /home/cvs/postgis/postgis/doc/man/shp2pgsql.1,v
> retrieving revision 1.3
> diff -u -r1.3 shp2pgsql.1
> --- doc/man/shp2pgsql.1	5 Apr 2005 13:43:50 -0000	1.3
> +++ doc/man/shp2pgsql.1	5 Apr 2005 14:17:09 -0000
> @@ -26,8 +26,14 @@
>  Creates a new table and populates it from the Shape file. This is the default mode.
>  .TP
> +\fB\-p\fR
> +Only produces the table creation SQL code, without adding any actual data. This can
> +be used if you need to completely separate the table creation and data loading steps.
> +.TP
>  \fB\-D\fR
> -Use the PostgreSQL "dump" format for the output data. This can be combined with -d, -a and -c and is much faster to load than the default "insert" SQL format. Use this for very large data sets.
> +Use the PostgreSQL "dump" format for the output data. This can be combined with -a, -c and -d.
> +It is much faster to load than the default "insert" SQL format. Use this for very large data sets.
>  .TP
>  \fB\-s\fR <\fISRID\fR>
> @@ -47,6 +53,9 @@
>  Note that this will introduce coordinate drifts and will drop
>  M values from shapefiles.
> +.LP
> +Note that -a, -c, -d and -p are mutually exclusive.
>  .SH "EXAMPLES"
>  .LP
>  An example session using the loader to create an input file and uploading it might look like this:
> Index: loader/README.shp2pgsql
> RCS file: /home/cvs/postgis/postgis/loader/README.shp2pgsql,v
> diff -u -r1.3 README.shp2pgsql
> --- loader/README.shp2pgsql	4 May 2002 22:44:04 -0000	1.3
> +++ loader/README.shp2pgsql	5 Apr 2005 14:17:09 -0000
> @@ -38,19 +38,23 @@
>  The options are as follows:
> -(-a || -c || -d) these options are mutually exclusive.
> +(-a || -c || -d || -p) these options are mutually exclusive.
>    -a    Append mode. Do not delete the target table or try to create
>          a new table, simple insert the data into the existing table.
>          A table will have to exist for this to work, it is usually
> -        used after a create mode as been run once.(mutually exclusive
> -	with -c and -d)
> +        used after a create mode as been run once or after -p. (mutually
> +        exclusive with -c, -d and -p)
>    -c    Create mode. This is the default mode is no other is specified.
>  	Create a new table and upload the data into that table.
> -	(mutually exclusive with -a and -d)
> +	(mutually exclusive with -a, -d and -p)
>    -d    Delete mode. Delete the database table named <tablename>, then
>  	create a new one with that name before uploading the data into
> -	the new empty database table.(mutually exclusive with -a and -c)
> +	the new empty database table. (mutually exclusive with -a, -c
> +        and -p)
> +  -p    Prepare mode. Read the table schema from the shape file and
> +        create the new table, but do not insert any data. (mutually
> +        exclusive with -a, -c and -d)
>    -D Dump. When inserting the data into the table use 'dump' format.
>  	Dump format is used by PostgreSQL for large data dumps and
> Index: loader/shp2pgsql.c
> RCS file: /home/cvs/postgis/postgis/loader/shp2pgsql.c,v
> retrieving revision 1.84
> diff -u -r1.84 shp2pgsql.c
> --- loader/shp2pgsql.c	4 Apr 2005 20:51:26 -0000	1.84
> +++ loader/shp2pgsql.c	5 Apr 2005 14:17:11 -0000
> @@ -92,6 +92,7 @@
>  int PIP( Point P, Point* V, int n );
>  void *safe_malloc(size_t size);
>  void create_table(void);
> +int load_data(int num_entities, int trans);
>  void usage(char *me, int exitcode);
>  void InsertPoint(void);
>  void InsertPointWKT(void);
> @@ -532,9 +533,9 @@
>  	printf("BEGIN;\n");
>  	//if opt is 'a' do nothing, go straight to making inserts
> -	if(opt == 'c' || opt == 'd') create_table();
> +	if(opt == 'c' || opt == 'd' || opt == 'p') create_table();
> -	if (dump_format){
> +	if (dump_format && opt != 'p'){
>  		if ( schema )
>  			printf("COPY \"%s\".\"%s\" %s FROM stdin;\n",
> @@ -547,10 +548,40 @@
> -	obj = SHPReadObject(hSHPHandle,0);
> +        if (opt != 'p') { /*only if we do not have prepare mode*/
> +                j = load_data(num_entities, trans);
> +        free(col_names);
> +	if(opt != 'a')
> +		if ( schema )
> +			printf("\nALTER TABLE ONLY \"%s\".\"%s\" ADD CONSTRAINT \"%s_pkey\" PRIMARY KEY (gid);\n",schema,table,table);
> +			if(j > 1 && opt != 'p')
> +				printf("SELECT setval ('\"%s\".\"%s_gid_seq\"', %i, true);\n", schema, table, j-1);
> +		else
> +			printf("\nALTER TABLE ONLY \"%s\" ADD CONSTRAINT \"%s_pkey\" PRIMARY KEY (gid);\n",table,table);
> +			if(j > 1 && opt != 'p'){
> +				printf("SELECT setval ('\"%s_gid_seq\"', %i, true);\n", table, j-1);
> +	printf("END;\n"); //End the last transaction
> +	return(1);
> +}//end main()
> +int
> +load_data(int num_entities, int trans) {
> +        int j;
>   *   MAIN SHAPE OBJECTS SCAN
> @@ -643,41 +674,16 @@
>  				break;
>  		SHPDestroyObject(obj);
>  	} // END of MAIN SHAPE OBJECT LOOP
>  	if ((dump_format) ) {
>  		printf("\\.\n");
> -	free(col_names);
> -	if(opt != 'a')
> -		if ( schema )
> -			printf("\nALTER TABLE ONLY \"%s\".\"%s\" ADD CONSTRAINT \"%s_pkey\" PRIMARY KEY (gid);\n",schema,table,table);
> -			if(j > 1)
> -				printf("SELECT setval ('\"%s\".\"%s_gid_seq\"', %i, true);\n", schema, table, j-1);
> -		else
> -			printf("\nALTER TABLE ONLY \"%s\" ADD CONSTRAINT \"%s_pkey\" PRIMARY KEY (gid);\n",table,table);
> -			if(j > 1){
> -				printf("SELECT setval ('\"%s_gid_seq\"', %i, true);\n", table, j-1);
> -	printf("END;\n"); //End the last transaction
> -	return(1);
> -}//end main()
> +        return j;
>  void
>  create_table(void)
> @@ -783,13 +789,14 @@
>  	fprintf(stderr, "OPTIONS:\n");
>  	fprintf(stderr, "  -s <srid>  Set the SRID field. If not specified it defaults to -1.\n");
>  	fprintf(stderr, "\n");
> -	fprintf(stderr, "  (-d|a|c) These are mutually exclusive options:\n");
> -	fprintf(stderr, "      -d  Drops the table , then recreates it and populates\n");
> +	fprintf(stderr, "  (-d|a|c|p) These are mutually exclusive options:\n");
> +	fprintf(stderr, "      -d  Drops the table, then recreates it and populates\n");
>  	fprintf(stderr, "          it with current shape file data.\n");
>  	fprintf(stderr, "      -a  Appends shape file into current table, must be\n");
>  	fprintf(stderr, "          exactly the same table schema.\n");
>  	fprintf(stderr, "      -c  Creates a new table and populates it, this is the\n");
>  	fprintf(stderr, "          default if you do not specify any options.\n");
> +	fprintf(stderr, "      -p  Only creates the table.");
>  	fprintf(stderr, "  -g <geometry_column> Specify the name of the geometry column\n");
>  	fprintf(stderr, "     (mostly useful in append mode).\n");
> @@ -1372,7 +1379,7 @@
>  	int curindex=0;
>  	char  *ptr;
> -	while ((c = getopt(ARGC, ARGV, "kcdaDs:g:iW:w")) != EOF){
> +	while ((c = getopt(ARGC, ARGV, "kcdapDs:g:iW:w")) != EOF){
>                 switch (c) {
>                 case 'c':
>                      if (opt == ' ')
> @@ -1392,6 +1399,12 @@
>                      else
>                           return 0;
>                      break;
> +	       case 'p':
> +                    if (opt == ' ')
> +                         opt ='p';
> +                    else
> +                         return 0;
> +                    break;
>  	       case 'D':
>  		    dump_format =1;
>                      break;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
