[postgis-devel] loader incompatibility
strk at refractions.net
Wed Apr 6 03:25:56 PDT 2005
Markus, I'm doing the big cleanup myself.
Please stop producing patches or I'll feel too guilty :P
I'll put the -p switch in.
--strk;
On Tue, Apr 05, 2005 at 10:44:22PM +0200, Markus Schaber wrote:
> Hi, @all,
> Here's another version of the patch. Apart from the documentation
> updates, it tries to be as less invasive as possible. I even did not
> re-indent the if()-encapsulated main loop.
> Markus
> Index: doc/postgis.xml
> RCS file: /home/cvs/postgis/postgis/doc/postgis.xml,v
> retrieving revision 1.135
> diff -u -r1.135 postgis.xml
> --- doc/postgis.xml 5 Apr 2005 08:00:07 -0000 1.135
> +++ doc/postgis.xml 5 Apr 2005 20:39:38 -0000
> @@ -1283,13 +1283,23 @@
> </varlistentry>
> <varlistentry>
> + <term>-p</term>
> + <listitem>
> + <para>Only produces the table creation SQL code, without adding
> + any actual data. This can be used if you need to completely
> + separate the table creation and data loading steps.</para>
> + </listitem>
> + </varlistentry>
> + <varlistentry>
> <term>-D</term>
> <listitem>
> - <para>Creates a new table and populates it from the Shape file.
> - This uses the PostgreSQL "dump" format for the output data and
> - is much faster to load than the default "insert" SQL format. Use
> - this for very large data sets.</para>
> + <para>Use the PostgreSQL "dump" format for the output data. This
> + can be combined with -a, -c and -d. It is much faster to load
> + than the default "insert" SQL format. Use this for very large data
> + sets.</para>
> </listitem>
> </varlistentry>
> @@ -1334,6 +1344,8 @@
> </variablelist>
> + <para>Note that -a, -c, -d and -p are mutually exclusive.</para>
> <para>An example session using the loader to create an input file and
> uploading it might look like this:</para>
> Index: doc/man/shp2pgsql.1
> RCS file: /home/cvs/postgis/postgis/doc/man/shp2pgsql.1,v
> retrieving revision 1.3
> diff -u -r1.3 shp2pgsql.1
> --- doc/man/shp2pgsql.1 5 Apr 2005 13:43:50 -0000 1.3
> +++ doc/man/shp2pgsql.1 5 Apr 2005 20:39:38 -0000
> @@ -26,8 +26,14 @@
> Creates a new table and populates it from the Shape file. This is the default mode.
> .TP
> +\fB\-p\fR
> +Only produces the table creation SQL code, without adding any actual data. This can
> +be used if you need to completely separate the table creation and data loading steps.
> +.TP
> \fB\-D\fR
> -Use the PostgreSQL "dump" format for the output data. This can be combined with -d, -a and -c and is much faster to load than the default "insert" SQL format. Use this for very large data sets.
> +Use the PostgreSQL "dump" format for the output data. This can be combined with -a, -c and -d.
> +It is much faster to load than the default "insert" SQL format. Use this for very large data sets.
> .TP
> \fB\-s\fR <\fISRID\fR>
> @@ -47,6 +53,9 @@
> Note that this will introduce coordinate drifts and will drop
> M values from shapefiles.
> +.LP
> +Note that -a, -c, -d and -p are mutually exclusive.
> .SH "EXAMPLES"
> .LP
> An example session using the loader to create an input file and uploading it might look like this:
> Index: loader/README.shp2pgsql
> RCS file: /home/cvs/postgis/postgis/loader/README.shp2pgsql,v
> diff -u -r1.3 README.shp2pgsql
> --- loader/README.shp2pgsql 4 May 2002 22:44:04 -0000 1.3
> +++ loader/README.shp2pgsql 5 Apr 2005 20:39:38 -0000
> @@ -38,19 +38,23 @@
> The options are as follows:
> -(-a || -c || -d) these options are mutually exclusive.
> +(-a || -c || -d || -p) these options are mutually exclusive.
> -a Append mode. Do not delete the target table or try to create
> a new table, simple insert the data into the existing table.
> A table will have to exist for this to work, it is usually
> - used after a create mode as been run once.(mutually exclusive
> - with -c and -d)
> + used after a create mode as been run once or after -p. (mutually
> + exclusive with -c, -d and -p)
> -c Create mode. This is the default mode is no other is specified.
> Create a new table and upload the data into that table.
> - (mutually exclusive with -a and -d)
> + (mutually eclusive with -a, -d and -p)
> -d Delete mode. Delete the database table named <tablename>, then
> create a new one with that name before uploading the data into
> - the new empty database table.(mutually exclusive with -a and -c)
> + the new empty database table. (mutually exclusive with -a, -c
> + and -p)
> + -p Prepare mode. Read the table schema from the shape file and
> + create the new table, but do not insert any data. (mutually
> + exclusive with -a, -c and -d)
> -D Dump. When inserting the data into the table use 'dump' format.
> Dump format is used by PostgreSQL for large data dumps and
> Index: loader/shp2pgsql.c
> RCS file: /home/cvs/postgis/postgis/loader/shp2pgsql.c,v
> retrieving revision 1.84
> diff -u -r1.84 shp2pgsql.c
> --- loader/shp2pgsql.c 4 Apr 2005 20:51:26 -0000 1.84
> +++ loader/shp2pgsql.c 5 Apr 2005 20:39:40 -0000
> @@ -532,9 +532,9 @@
> printf("BEGIN;\n");
> //if opt is 'a' do nothing, go straight to making inserts
> - if(opt == 'c' || opt == 'd') create_table();
> + if(opt == 'c' || opt == 'd' || opt == 'p') create_table();
> - if (dump_format){
> + if (dump_format && opt != 'p'){
> if ( schema )
> printf("COPY \"%s\".\"%s\" %s FROM stdin;\n",
> @@ -555,8 +555,9 @@
> * MAIN SHAPE OBJECTS SCAN
> - for (j=0;j<num_entities; j++)
> + if (opt != 'p') { /*only if we do not have prepare mode*/
> + for (j=0;j<num_entities; j++)
> //wrap a transaction block around each 250 inserts...
> if ( ! dump_format )
> @@ -646,12 +647,12 @@
> SHPDestroyObject(obj);
> - } // END of MAIN SHAPE OBJECT LOOP
> + } // END of MAIN SHAPE OBJECT LOOP
> - if ((dump_format) ) {
> + if ((dump_format) ) {
> printf("\\.\n");
> free(col_names);
> @@ -660,7 +661,7 @@
> if ( schema )
> printf("\nALTER TABLE ONLY \"%s\".\"%s\" ADD CONSTRAINT \"%s_pkey\" PRIMARY KEY (gid);\n",schema,table,table);
> - if(j > 1)
> + if(j > 1 && opt != 'p')
> printf("SELECT setval ('\"%s\".\"%s_gid_seq\"', %i, true);\n", schema, table, j-1);
> @@ -668,7 +669,7 @@
> else
> printf("\nALTER TABLE ONLY \"%s\" ADD CONSTRAINT \"%s_pkey\" PRIMARY KEY (gid);\n",table,table);
> - if(j > 1){
> + if(j > 1 && opt != 'p'){
> printf("SELECT setval ('\"%s_gid_seq\"', %i, true);\n", table, j-1);
> @@ -783,13 +784,14 @@
> fprintf(stderr, "OPTIONS:\n");
> fprintf(stderr, " -s <srid> Set the SRID field. If not specified it defaults to -1.\n");
> fprintf(stderr, "\n");
> - fprintf(stderr, " (-d|a|c) These are mutually exclusive options:\n");
> + fprintf(stderr, " (-d|a|c|p) These are mutually exclusive options:\n");
> fprintf(stderr, " -d Drops the table , then recreates it and populates\n");
> fprintf(stderr, " it with current shape file data.\n");
> fprintf(stderr, " -a Appends shape file into current table, must be\n");
> fprintf(stderr, " exactly the same table schema.\n");
> fprintf(stderr, " -c Creates a new table and populates it, this is the\n");
> fprintf(stderr, " default if you do not specify any options.\n");
> + fprintf(stderr, " -p Prepare mode, only creates the table\n");
> fprintf(stderr, " -g <geometry_column> Specify the name of the geometry column\n");
> fprintf(stderr, " (mostly useful in append mode).\n");
> @@ -1372,7 +1374,7 @@
> int curindex=0;
> char *ptr;
> - while ((c = getopt(ARGC, ARGV, "kcdaDs:g:iW:w")) != EOF){
> + while ((c = getopt(ARGC, ARGV, "kcdapDs:g:iW:w")) != EOF){
> switch (c) {
> case 'c':
> if (opt == ' ')
> @@ -1392,6 +1394,12 @@
> else
> return 0;
> break;
> + case 'p':
> + if (opt == ' ')
> + opt ='p';
> + else
> + return 0;
> + break;
> case 'D':
> dump_format =1;
> break;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
