[postgis-devel] Re: debian postgis
alex bodnaru
alexbodn at 012.net.il
Thu Apr 14 17:51:15 PDT 2005
postgresql-dev package is been really used for the postgres api headers,
while the configuration files are been needed because they are been
included by the makefile.global and makefile.shlib, required in the
postgis build process.
if you could finaly decide to selectively ask for locations of
postgresql files such as libdir, datadir and bindir, you will find all
those values using pg_config, instead of including the makefiles from
postgresql.
best regards,
alex
On Thu, 2005-04-14 at 18:25 +0200, Markus Schaber wrote:
> Hi, Strk,
> Hi, Alex,
> strk at refractions.net schrieb:
> > The debian/ subdir is huge: 2.5Mb of disk space.
> The most of this space seems to be from the autoconf scripts in the
> postgresql source archives. I think it should be possible to get all
> that's needed to compile postgresql extensions via a build dependency on
> the the postgresql-dev package, if not, this seems to be a bug in the
> postgresql-dev package.
> Markus
