[postgis-devel] Re: debian postgis
Markus Schaber schabi at logix-tt.com
Fri Apr 15 01:53:42 PDT 2005
Hi, alex,
alex bodnaru schrieb:
> postgresql-dev package is been really used for the postgres api headers,
> while the configuration files are been needed because they are been
> included by the makefile.global and makefile.shlib, required in the
> postgis build process.
> if you could finaly decide to selectively ask for locations of
> postgresql files such as libdir, datadir and bindir, you will find all
> those values using pg_config, instead of including the makefiles from
> postgresql.
I think this is a good idea, and should be integrated with the autoconf
work, but IMHO this clearly should be delayed after 1.0.0 final.
BTW, does pg_config exist on woody?
Markus
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050415/6ad5389d/attachment.sig>
