[postgis-devel] postgresql source dependency
strk at refractions.net strk at refractions.net
Fri Apr 15 02:03:16 PDT 2005
I never understood the pgsql Makefile dependency and I'll be happy
to drop it.
I think the biggest problem is having to rewrite (or copy actually) the
rules for shared lib building (which I think detect
naming and appropriate compiler/linker flags - basically we're
piggybacking the pgsql autoconf...).
PostGIS autoconf support is currently very basic, no automake, no
libtool. I wonder how many problems we might encounter with this
essential setup on mingw/cygwin/OSX/Solaris/whatever...
Requires much testing, I belive could be done for 1.1.0.
--strk;
On Fri, Apr 15, 2005 at 10:53:42AM +0200, Markus Schaber wrote:
> Hi, alex,
> alex bodnaru schrieb:
> > postgresql-dev package is been really used for the postgres api headers,
> > while the configuration files are been needed because they are been
> > included by the makefile.global and makefile.shlib, required in the
> > postgis build process.
> > if you could finaly decide to selectively ask for locations of
> > postgresql files such as libdir, datadir and bindir, you will find all
> > those values using pg_config, instead of including the makefiles from
> > postgresql.
> I think this is a good idea, and should be integrated with the autoconf
> work, but IMHO this clearly should be delayed after 1.0.0 final.
> BTW, does pg_config exist on woody?
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
