[postgis-devel] Re: debian postgis
alex bodnaru
alexbodn at 012.net.il
Fri Apr 15 03:57:21 PDT 2005
yes, it does.
alex
On Fri, 2005-04-15 at 12:44 +0200, strk at refractions.net wrote:
> On Fri, Apr 15, 2005 at 01:47:12PM +0300, alex bodnaru wrote:
> > hi markus,
> > woody has postgresql 7.2.1, with pg_config equally good.
> Does it have --pkglibdir ?
> --strk;
> > alex
> > On Fri, 2005-04-15 at 10:53 +0200, Markus Schaber wrote:
> > > Hi, alex,
> > > alex bodnaru schrieb:
> > > > postgresql-dev package is been really used for the postgres api headers,
> > > > while the configuration files are been needed because they are been
> > > > included by the makefile.global and makefile.shlib, required in the
> > > > postgis build process.
> > > > if you could finaly decide to selectively ask for locations of
> > > > postgresql files such as libdir, datadir and bindir, you will find all
> > > > those values using pg_config, instead of including the makefiles from
> > > > postgresql.
> > > I think this is a good idea, and should be integrated with the autoconf
> > > work, but IMHO this clearly should be delayed after 1.0.0 final.
> > > BTW, does pg_config exist on woody?
> > > Markus
> > > _______________________________________________
> > > postgis-devel mailing list
> > > postgis-devel at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
