[postgis-devel] 1.0 branch
strk at refractions.net strk at refractions.net
Fri Apr 15 04:51:29 PDT 2005
pgis_1_0 branch is set. 1.0.0 will come out from there.
HEAD is open for changes. Here's a brief list of items
for 1.1 that I've in mind and are not present in the TODO:
	- PGsql sources dependency drop
	- Full autoconf support
	- Special threatment of SRID=-1, dims=-1, type=GEOMETRY
	  in geometry_columns
	- Better upgrade mechanism
	- Pre-8.0 port of new estimator code
	- Better regression tests (single load, multi operations)
	- contrib/ dir with WFSLocks and packaging files ?
	- <your feature-request here>
Actual items to be work on will obviously require a scan of the TODO,
and priority assignment, we have most notably:
	- network operations
	- multi-dimensional indexing
--strk;
