[postgis-devel] 1.0 branch
strk at refractions.net strk at refractions.net
Fri Apr 15 05:30:54 PDT 2005
On Fri, Apr 15, 2005 at 02:26:55PM +0200, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net schrieb:
> > 	- <your feature-request here>
> I have around 66k worth of changes for jdbc2 pending, including working
> optional JTS support, extended regression tests and a new autoprobing
> DriverWrapper that detects the PostGIS Server version on connection time
> to decide whether to send EWKT or HexWKB to the server.
> I held those changes back as I did not want to destabilize the 1.0.0
> branch. I hope I can commit them on Monday after merging them and
> running a first test against the new postgresql-8.1dev-400.jdbc3.jar.
You can commit them now in the HEAD branch.
I didn't plan any merging, but intended to keep the 1.0 branch
for 1.0.# and use HEAD for 1.1.0. The only planned change in 1.0
branch is update of release dates...
--strk;
> The JTS support makes it possible to create a new kind of regression
> test that runs the same spatial operations in JTS and on the Server and
> then compare the results. However, there are no such tests yet.
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
