[postgis-devel] Re: [postgis-users] WARNING: cache reference leak: cache pg_statistic (31), tuple 0 has count 1
strk at refractions.net strk at refractions.net
Mon Apr 18 02:47:19 PDT 2005
Patch sounds good, altought I think we can do something better
in case number of table tuples are unknown (no vacuum run on them).
I'm doing some final run tests before committing it (1.0.0 will
wait for this).
--strk;
On Mon, Apr 18, 2005 at 01:11:21AM -0700, Ron Mayer wrote:
> While, I'm at it, I think this patch fixes both the problems.
> In LWGEOM_gist_joinsel() inside #ifdef REALLY_DO_JOINSEL I think I see
> two problems.
> 1.  It can divide by zero, causing a
>        "ERROR:  invalid join selectivity: inf"
>     error.   I work around this by returning DEFAULT_GEOMETRY_SEL
>     if the thing on the bottom in that division was zero.
> 2.  I think it can do a "SearchSysCache()" and "get_attstatsslot()"
>     for stats1_tuple without a corresponding "RelasesSysCache()" or
>     "free_attstatsslot()" in the case when stats2_tuple has no
>     statistics.   I work around this by putting in the
>     calls to
>      free_attstatsslot(0, NULL, 0, (float *)geomstats1, geomstats1_nvalues);
>      ReleaseSysCache(stats1_tuple);
>     in the places where I do an early return because of stats2_tuple.
> Am I on the right track?   It seems to make the problem go
> away for me, but I'm not that familiar with the code...
>    Ron
> rmap:~/apps/tmp/postgresql-8.0.2/contrib/postgis-cvs/lwgeom> diff -c
> lwgeom_estimate.c.~1~  lwgeom_estimate.c
> *** lwgeom_estimate.c.~1~       Fri Mar 25 01:34:25 2005
> --- lwgeom_estimate.c   Sun Apr 17 09:04:57 2005
> *** 25,31 ****
>   #include "liblwgeom.h"
>   #include "lwgeom_pg.h"
> ! //#define DEBUG_GEOMETRY_STATS 1
>   #if USE_VERSION >= 80
> --- 25,31 ----
> ! #define DEBUG_GEOMETRY_STATS 1
> *** 867,872 ****
> --- 867,874 ----
>   #if DEBUG_GEOMETRY_STATS
>                 elog(NOTICE, " No statistics, returning default estimate");
>   #endif
> +               free_attstatsslot(0, NULL, 0, (float *)geomstats1,
> +               ReleaseSysCache(stats1_tuple);
>                 PG_RETURN_FLOAT8(DEFAULT_GEOMETRY_SEL);
> *** 878,883 ****
> --- 880,887 ----
>                 elog(NOTICE, " STATISTIC_KIND_GEOMETRY stats not found -
>                 returning default geometry selectivity");
>   #endif
>                 ReleaseSysCache(stats2_tuple);
> *** 963,968 ****
> --- 967,976 ----
>         elog(NOTICE, "Estimated rows returned: %f", rows_returned);
>   #endif
> +         /* avoid a "ERROR:  invalid join selectivity: inf" */
> +         if (total_tuples==0)
> +             PG_RETURN_FLOAT8(DEFAULT_GEOMETRY_JOINSEL);
>         PG_RETURN_FLOAT8(rows_returned / total_tuples);
> Ron Mayer wrote:
> >I have some queries that are giving me a
> >  " WARNING:  cache reference leak: cache pg_statistic (31), tuple 0 has
> >count 1 "
> >warning message in my log file when I run them.
> >I'm using a couple days ago's (either thursday or friday's) CVS version.
> >According to the wonderfully helpful people on postgresql's IRC,
> > "the catcache issues that warning at the end of a transaction if
> >  there are outstanding references to cached items ...
> >  since it's pg_statistic that is being complained about, the most
> >  likely culprit is a selectivity estimator function.. since those
> >  use rows from pg_statistic to base estimates on"
> >The problem goes away if I "ANALYZE" all my tables involved in the query.
> >I can re-create the problem by doing TRUNCATE TABLE on the table
> >wiith the MULTIPOLYGON and re-inserting the data, and running the
> >query before analyzing that table.
> >Below is
> >   1.  An example query that shows the problem. It's joining a POINT
> >       from the table point_features with a MULTIPOLYGON from the
> >       table area_features.
> >   2.  The output from select * from postgis_full_version();
> >       and
> >   3.  A previous message from this list that I think might be related;
> >       since this is the same kind of query that was giving me
> >       errors with RC4 when I had non-recently analyzed tables.
> >   Ron
> >=== My problem query
> >fli=# select *
> >        from userfeatures.point_features upf,
> >        userfeatures.area_features uaf
> >  where upf.the_geom && uaf.the_geom
> >    and intersects(upf.the_geom,uaf.the_geom)
> >    and uaf.featureid=18 limit 1
> >fli-# fli-# fli-# fli-# fli-# ;
> >count 1
> > pointid | featureid | sessionid |   userid   | extid | label | iconid
> >|                  the_geom                  | entity_id | areaid |
> >featureid | session\
> >id |   userid   | extid | label | color | bordercolor
> >the_geom
> >    3391 |        20 |         0 | 1635480986 | -1    |       |      1 |
> >010100000018E29102631355C0606B040DBF743E40 |     29646 |     57 |
> >18 |        \
> > 0 | 1635480986 |       |       | green | green       |
> >0106000000010000000103000000010000002300000001ACAD4CE01255C02B7ED6AE7A723E407E0D4B0DFB1255C0E0E5C5FE7D\
> >723E40BC2EF520151355C01929CF1E96723E403A4C21872D1355C049D49A21C2723E40B9F3C54F431355C0A4E22E5600733E40F87B94A4551355C0DC5692584E733E40185C35D1631355C054C75129\
> >A9733E40E05C364A6D1355C00D80FD4A0D743E407F7566B2711355C08C147FE476743E40929B6ADE701355C07F9AF4E6E1743E40C34A68D66A1355C0771F9D354A753E40F85FB5D55F1355C070954D\
> >CEAB753E40615C9048501355C06A33E0F002763E40537FF7C73C1355C067541A444C763E4035A3C713261355C0E9D49DF684763E4006B55C0B0D1355C005D8A1DAAA763E40E74FFCA4F21255C0833A\
> >627BBC763E407C938711DA1255C0EBECE119C3763E40FF31EA50BF1255C03685F2C9BF763E40C110403DA51255C0FD41E9A9A7763E4043F313D78C1255C0CD961DA77B763E40C44B6F0E771255C072\
> >8889723D763E4085C3A0B9641255C03A142670EF753E4065E3FF8C561255C0C2A3669F94753E409DE2FE134D1255C009EBBA7D30753E40FEC9CEAB481255C08A5639E4C6743E40EBA3CA7F491255C0\
> >97D0C3E15B743E40BAF4CC874F1255C09F4B1B93F3733E4085DF7F885A1255C0A6D56AFA91733E401CE3A4156A1255C0AC37D8D73A733E402AC03D967D1255C0AF169E84F1723E40489C6D4A941255\
> >C02D961AD2B8723E40778AD852AD1255C0119316EE92723E4096EF38B9C71255C09330564D81723E4001ACAD4CE01255C02B7ED6AE7A723E40
> >(1 row)
> >fli=#
> >fli=#
> >=========postgis_full_version()
> >fli=# select * from postgis_full_version();
> > POSTGIS="1.0.0RC6" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> >USE_STATS DBPROC="0.3.0" RELPROC="0.3.0"
> >(1 row)
> >fli=#
> >==== possibly related earlier conversation, that I don't remember
> >==== the conclusion of.
> >(Re: [postgis-users] ERROR:  invalid join selectivity: inf)
> >strk at refractions.net wrote:
> >>Mark, can you look at this ?
> >>As a short-term workaround, in lwgeom_estimate.c line 100:
> >>#define REALLY_DO_JOINSEL 0
> >>--strk;
> >>On Fri, Mar 04, 2005 at 03:01:32AM -0800, Ron Mayer wrote:
> >>>Ok.. I think I can reproduce this:
> >>>>  fl# select * from rtgr.landpoly,userfeatures.areas
> >>>>      where rtgr.landpoly.the_geom && userfeatures.areas.the_geom;
> >>>pretty easily.
> >>>Every time I "truncate table userfeatures.areas", and insert
> >>>some areas; I'll get that error message until I "analyze areas".
> >>>Seems like a bug when the stastics generated by analyze thinks
> >>>that a table is empty while in reality it isn't.
> >>>_______________________________________________
> >>>postgis-users mailing list
> >>>postgis-users at postgis.refractions.net
> >>>http://postgis.refractions.net/mailman/listinfo/postgis-users
