[postgis-devel] RE: estimates problems and 1.0.0 delay
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Mon Apr 18 04:46:11 PDT 2005
Hi strk/Ron,
> -----Original Message-----
> From: strk at refractions.net [mailto:strk at refractions.net]
> Sent: 18 April 2005 12:08
> To: rm_postgis at cheapcomplexdevices.com; Mark Cave-Ayland
> (External); postgis-devel at postgis.refractions.net
> Subject: estimates problems and 1.0.0 delay
> I've committed Ron's patch, but making some tests I
> discovered some corner cases still unandled.
> It is collapsed histogram extent, mostly due to standard
> deviation based hard deviants cut-off. Problem is that after
> cut-off of hard deviants we end up with a 0-size dimension on Y or X.
> This is surely NOT something that happens on a normal
> database usage but I think we should farther inspect it and
> find a workaround. Sounds as a can o worms so I wouldn't open
> it before 1.0.0 which was planned for today, but I'd delay
> release until tomorrow evening
> (CET) to allow a few more tests to be performed by Ron and
> eventually Mark (and myself, of course).
I agree, we could do with having a workaround on this. For example, what
happens if you load a single point into a geometry table and then ANALYZE?
Will that also produce a 0 sized dimension in Y and X?
My current thinking would be to enforce a minimum (non-zero) histogram size,
much along the lines that new tables default to returning 1000 rows until
statistics information becomes available. Then if we find X or Y collapses
to a zero dimension then we add some default (small) offsets and use this as
the size of the X or Y histogram instead. This should only be an issue on
small or artificial datasets, so if the estimates come out slightly less
accurate for just these cases then we shouldn't have too much of a problem.
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
