[postgis-devel] 1.0 branch
strk at refractions.net strk at refractions.net
Mon Apr 18 07:24:53 PDT 2005
On Fri, Apr 15, 2005 at 03:34:48PM +0200, Jean David TECHER wrote:
> Hi again Sandro
> When I compiled in Windows (with TeXLive latex) the doc by
> pdfxmltex postgis.fo
> in postgis/doc/postgis.pdf  (see attached file)
> there are others contributors..;Great to see Klaus has been added :-)
Unfortunately the contributors section is flattened out, but
I think we really should evidence Mark Cave Ayland and Markus Shaber...
Paul, can you find a formula for this ?
--strk;
> ----- Original Message -----
> From: <strk at refractions.net>
> To: <postgis-devel at postgis.refractions.net>
> Cc: "Paul Ramsey" <pramsey at refractions.net>
> Sent: Friday, April 15, 2005 1:51 PM
> Subject: [postgis-devel] 1.0 branch
> > pgis_1_0 branch is set. 1.0.0 will come out from there.
> > HEAD is open for changes. Here's a brief list of items
> > for 1.1 that I've in mind and are not present in the TODO:
> > - PGsql sources dependency drop
> > - Full autoconf support
> > - Special threatment of SRID=-1, dims=-1, type=GEOMETRY
> >   in geometry_columns
> > - Better upgrade mechanism
> > - Pre-8.0 port of new estimator code
> > - Better regression tests (single load, multi operations)
> > - contrib/ dir with WFSLocks and packaging files ?
> > - <your feature-request here>
> > Actual items to be work on will obviously require a scan of the TODO,
> > and priority assignment, we have most notably:
> > - network operations
> > - multi-dimensional indexing
> > --strk;
> > postgis-devel mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
