[postgis-devel] pg_opclass and schema awareness
Carl Anderson
carl.anderson at co.fulton.ga.us
Tue Apr 19 12:38:50 PDT 2005
Markus Schaber wrote:
>Hi,
>I just wanted to bring this issue up onto the table, as it was held back
>due to the 1.0.0 freeze. (see below)
>Is this change the correct fix? Should I commit it, or is it better to
>fix all schema issues at once?
>Maybe it would simply be the best to tell our users not to install
>different PostGIS versions into different schemas of the same database.
I believe that it is critical that only one PostGIS version be allowed
on a server at a time.
Otherwise the potentially different WKT and WKB parsers could refuse to
read each others output. Also there is no implicit cast from the
my.geometry type to the your.geometry type and potentially no valid cast
between the two.
WRT spatial_ref_sys and geometry_columns. I believe that it is helpful
to find these
through the implicit object search path and not require them to be in
any particular schema.
That way it would not be necessary to grant potentially excessive
permissions to the geometry_columns table.
I am think about a classroom setting wherein each student is directed to
work within
a schema carrying their own userid (which would be the first component
of the students search path). Each student could have complete
authority over their own parts and not
be able to disrupt other students work.
C.
>Markus
>Markus Schaber schrieb:
>>Hi, strk,
>>strk at refractions.net schrieb:
>>>>It should be possible having different directories, as postgresql uses
>>>>full qualified file names. But I have to admit that you cannot simply
>>>>use "make install" unmodified.
>>>Since you pointed out... actually you can ;)
>>>LPATH=/usr/src/postgis-modified make
>>Okay - I used a search/replace on lwpostgis.sql :-)
>>Here's the proof - two different compilations of the same postgis
>>version in two different schemas in the same database:
>>multipostgis=# select
>>schabi.postgis_lib_build_date(),schabi.postgis_version(),postgres.postgis_lib_build_date(),postgres.postgis_version();
>> postgis_lib_build_date | postgis_version |
>> 2005-03-01 17:19:32 | 1.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 |
>>2005-03-01 17:22:27 | 1.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
>>(1 Zeile)
>>But, besides the library path, I also needed to comment out the lines
>>640-642 of lwpostgis.sql because the subselect returned more than one row.
>>UPDATE pg_opclass
>> SET opckeytype = (select oid from pg_type where typname = 'box2d')
>> WHERE opcname = 'gist_geometry_ops';
>>I'm afraid that this could break the GIST indices for schema users, we
>>should constrain the subselect to current_schema(). The following should
>>do this:
>>UPDATE pg_opclass
>> SET opckeytype = (SELECT oid FROM pg_type
>> WHERE typname = 'box2d'
>> AND typnamespace=(SELECT oid FROM pg_namespace
>> WHERE nspname=current_schema()))
>> AND opcnamespace = (SELECT oid from pg_namespace
>> WHERE nspname=current_schema());
>>Strk, could you verify this?
>>Markus
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
>This message has been scanned for viruses and
>dangerous content for Fulton County by DefendMail, and is
>believed to be clean.
Carl Anderson
GIS Manager Fulton County, Georgia
404.730.8026
