RES: RES: [postgis-devel] Autoprobing java source files
Gustavo Henrique Sberze Ribas
gribas at cpqd.com.br
Wed Apr 20 06:14:43 PDT 2005
Hallo Markus,
IMHO, the PostGIS jdbc2 package can be seen as a different
project, it doesn't need any PostGIS library to be compiled
nor PostGIS relies on it to function.
The only people interested in it are Java developers, which
I believe are much more confortable with ant then make.
Gruss,
Gustavo
> Hi, Gustavo,
> Gustavo Henrique Sberze Ribas schrieb:
> > Or, if I may abuse your good will, you could deliver an Ant
> > (java version of "make") build.xml. :)
> Originally, my jdbc2 code had partially replaced the old
> jdbc2 Makefile
> with an ant script.
> However, we wanted to avoid introducing an additional build
> dependency.
> And maintaining both the build.xml and Makefile in parallel
> would be too
> much effort and error-prone.
> I'm okay with replacing the jdbc2 Makefile with a full-featured
> build.xml, but I do not like to maintain both. So if the majority here
> thinks that ant is better for jdbc2, and the refractions people do not
> have any objections, I'll create a build.xml.
> Maybe a compromise would be to have a minimal Makefile that's just
> enough to build the jars, and have a fully featured build.xml that
> includes the tests etc. Or vice-versa.
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
