[postgis-devel] Re: [postgis-users] Building PostGIS from Sunday CVS..without PostgreSQL Sources...OK ! ! !
strk at refractions.net strk at refractions.net
Tue Apr 26 02:26:43 PDT 2005
On Tue, Apr 26, 2005 at 11:03:34AM +0200, Jean David TECHER wrote:
> My patch is attached to this mail (postgis_cvs.patch)...In order to applyng
> it (thanks to Gerald for patching :-))
> The last thing to do -  for people who wants to compil postgis on windows -
> is to take care of Docbook, iconv.dll and xsltproc
> Else 'make install' wil stop for "make -C doc"
This is true for all systems. Detecting iconv presence will allow
us to build shp2pgsql with or without utf8 support w/out user (or
packager usually) intervantion. Detecting xsltproc absence should
skip attempt at generating docs. Note anyway that postgis packages
come with documentation already generated, thus a make in doc
*should* tells you "nothing to be done here" or something similar.
Your mileage may vary of course... if this is not the case I'd
drop the default attempt at making docs in order to avoid a
dependency on xsltproc.
Some comments and questions on the patch:
> Here is the contense of the patch:
> --- postgis/Makefile.config.in Tue Apr 19 10:41:21 2005
> +++ postgis/Makefile.config.in Mon Apr 25 12:43:59 2005
> @@ -71,9 +71,13 @@
>  PGCONFIG=@PGCONFIG@
>  PGFEINCLUDES=@PGFEINCLUDES@
> +ifeq ($(findstring MINGW,$(MSYSTEM)),MINGW)
> +PGBEINCLUDES=@PGBEINCLUDES@ @PGBEINCLUDES@/port @PGBEINCLUDES@/port/win32
> @PGBEINCLUDES@/port/win32/arpa
> +PGFELIBS=$(shell @PGCONFIG@ --libdir)
> +else
>  PGFELIBS=@PGFELIBS@
> +endif
Here you're adding more server headers in case of a build against MINGW.
Question is: who is requiring this ? Which source files are trying
to include things which are not in PGBEINCLUDES (PostgreSQL Back-End
includes) ? Is there a different server-headers layout for postgresql
un unix and w32 systems ?
>  # Docbook
> @@ -112,8 +116,13 @@
>  # DLL
> -DLSUFFIX=@DLSUFFIX@
> -DLFLAGS=@DLFLAGS@
> + DLSUFFIX=.dll
> + DLFLAGS=@DLFLAGS@
> +else
> + DLSUFFIX=@DLSUFFIX@
> + DLFLAGS=@DLFLAGS@
> +endif
The value of DLSUFFIX sould be set by configure IMO, the "findstring"
call replaced by an invocation of uname probably. What does uname -s
returns there ?
>  # END OF CONFIGURATION
> --- postgis/loader/Makefile Mon Apr 18 14:46:48 2005
> +++ postgis/loader/Makefile Mon Apr 25 12:40:44 2005
> @@ -32,7 +32,13 @@
>   $(CC) $(CFLAGS) $(PGFEINCLUDES) -c $<
>  pgsql2shp$(EXE): $(OBJS) pgsql2shp.o PQunescapeBytea.o
> + $(CC) $(CFLAGS) $(OBJS) PQunescapeBytea.o pgsql2shp.o $(LDFLAGS)
> $(PGFELIBS)/libpq.a -o $@
> +else
>   $(CC) $(CFLAGS) $(PGFELIBS) $(OBJS) PQunescapeBytea.o pgsql2shp.o
> $(LDFLAGS) -o $@
> +endif
Why do you need to link statically against the libpq ?
>  shp2pgsql$(EXE): $(OBJS) shp2pgsql.o
>   $(CC) $(CFLAGS) $(OBJS) shp2pgsql.o $(LDFLAGS) -o $@
> --- postgis/lwgeom/Makefile Wed Apr 20 15:17:37 2005
> +++ postgis/lwgeom/Makefile Mon Apr 25 12:09:17 2005
> @@ -13,21 +13,32 @@
>  # Shared library parameters.
>  NAME=lwgeom
> +SHLIB           =
> lib$(NAME).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)$(DLSUFFIX)
> +SHLIB_MAJOR     = lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION)
> +SHLIB_BARE      = lib$(NAME)$(DLSUFFIX)
> +SHLIB_LINK  =
> +else
>  SHLIB           =
> lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
> -SHLIB_LINK  = $(DLFLAGS)
> +SHLIB_LINK  = $(DLFLAGS)
> +endif
>  MODULE_FILENAME = $(LPATH)/$(SHLIB)
>  # Postgis version and build date
> -POSTGIS_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
> USE_GEOS=$(USE_GEOS) USE_PROJ=$(USE_PROJ) USE_STATS=$(USE_STATS)
> -POSTGIS_LIB_VERSION =
> $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION).$(SO_MICRO_VERSION)
> -POSTGIS_BUILD_DATE := $(shell date -u "+%Y-%m-%d %H:%M:%S")
> + POSTGIS_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
> + POSTGIS_LIB_VERSION =
> + POSTGIS_BUILD_DATE := $(shell date -u "+%Y-%m-%d %H:%M:%S")
> +else
> +endif
Am I missing something or the two blocks (MINGW or not) are
exactly the same in both of the blocks above ?
> @@ -87,8 +98,17 @@
>  all: $(GEOS_RULES) $(SHLIB) ../lwpostgis.sql
> +#------------ It's for Win32 -----------------------------------
>  $(SHLIB): $(OBJS)
> + dlltool --export-all  --output-def lwgeom.def $(OBJS)
> + dllwrap  -o $@ --dllname $@ --def lwgeom.def $(OBJS)
> $(SHLIB_LINK) -L$(shell pg_config --libdir) -lpostgres
> + dlltool --dllname $@  --def lwgeom.def --output-lib liblwgeom.a
> +else
>   $(CC) $(SHLIB_LINK) -o $(SHLIB) $(OBJS)
> +endif
This should be fine, except last dlltool call is for building
the liblwgeom.a, which is not needed.
--strk;
>  wktparse.tab.c: wktparse.y
>   $(YACC) -vd -p lwg_parse_yy wktparse.y
> TECHER Jean David
> 01MAP
> e-mail: david at 01map.net
> Tél: 04 67 45 60 27
> Entreprise: http://www.01map.net
> Perso: http://techer.pascal.free.fr/postgis/
> ----- Original Message -----
> From: <strk at refractions.net>
> To: "Jean David TECHER" <davidtecher at yahoo.fr>
> Cc: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Monday, April 25, 2005 1:44 AM
> Subject: Re: [postgis-users] Building PostGIS from Sunday CVS..without
> > On Sun, Apr 24, 2005 at 07:39:38PM +0200, Jean David TECHER wrote:
> > > Hi Sandro and PostGIS'ers,
> > > Last Sunday, I decided to compil PostGIS from CVS (form sunday in the
> afternoon)...
> > > Since the goal is to build PostGIS WITHOUT PostgreSQL sources but from
> the binairies installed on the computer
> > > the tests on Windows for me is OK...Successfull...I did it for PG 8.0.2,
> Geos 2.1.1 and Proj 4.4.9
> > Good news!
> > Weird I didn't change anything since your worried mails ;)
> > > The only changes -I had to do - were to make few changes on:
> > > -1/ postgis/Makefile.config.in
> > > - 2/postgis/lwgeom/Makefile
> > > - 3/postgis/loader/Makefile
> > > For each file, I used
> > >      XXXXXXXXX
> > > else
> > >      XXXXXXXXXX
> > > endif
> > I'd put the XXXXXX all in Makefile.config.in.
> > > The changes in files are at the end of this files (sorry, I didn't at
> enough times to make patch... :-[ ....)
> > > Since i'm not at job on Monday but Tuesday, I will do a resume doc next
> Tuesday
> > > NOTICE: For creating postgis doc, I need to have
> docbook-xslt-stylesheets, xlstproc and icon.dll installed on
> Windows..Nevermind
> > > Just 3 downloading to do.
> > > cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis login
> > > cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis co postgis
> > > cd postgis
> > > autoconf
> > > configure --enable-autotconf --with-geos=`which geos-config`
> > If geos-config is in your PATH, which is what you expect using which,
> there should be
> > no need to be explicit. A simple --with-geos should work.
> > > make
> > > make install
> > > cd regress
> > > make
> > > Regression Tests, Loading some data with the laoder (...) work fine...
> > Thanks! See you on Tuesday with patches then :)
> > --strk;
> ========================================[postgis/Makefile.config.in ]=======
> > > # Configuration Directives
> > > # We recommend that you install the Proj4 and GEOS libraries
> > > # referenced below to get the most use out of your PostGIS
> > > # database.
> > > # Set USE_PROJ to 1 for Proj4 reprojection support (recommended)
> > > # Reprojection allows you to transform coordinate systems
> > > # in the database with the Transform() function.
> > > # Download from: http://www.remotesensing.org/proj
> > > USE_PROJ=@USE_PROJ@
> > > PROJ_DIR=@PROJ_DIR@
> > > # Set USE_GEOS to 1 for GEOS spatial predicate and operator
> > > # support (recommended).
> > > # GEOS installation directory defaults to /usr/local,
> > > # set GEOS_DIR environment variable to change it.
> > > # GEOS allows you to do exact topological tests, such as
> > > # Intersects() and Touches(), as well as geometry operations,
> > > # such as Buffer(), GeomUnion() and Difference().
> > > # Download from: http://geos.refractions.net
> > > USE_GEOS=@USE_GEOS@
> > > GEOS_DIR=@GEOS_DIR@
> > > # Set USE_JTS to 1 if you have libjts installed.
> > > USE_JTS=0
> > > JTS_INCLUDES=@JTS_INCLUDES@
> > > JTS_LIBDIR=@JTS_LIBDIR@
> > > # Set USE_STATS to 1 for new GiST statistics collection support
> > > # Note that this support requires additional columns in
> > > # GEOMETRY_COLUMNS, so see the list archives for info or
> > > # install a fresh database using postgis.sql.
> > > # This option is useless for builds against PGSQL>=80 (stats
> > > # are always gathered in that case, and you don't need additional
> > > # columns in geometry_columns).
> > > USE_STATS=1
> > > # Set AUTOCACHE_BBOX to 0 if you want finer control over
> > > # bounding box computation and caching for your geometries.
> > > # If you do, bbox computattion strategies are listed in
> > > # the file lwgeom/BBOXCACHE_BEHAVIOURS, but don't expect
> > > # them to be easy nor consistent.
> > > AUTOCACHE_BBOX=1
> > > # Set USE_ICONV to 1 if you want the loader (shp2pgsql)
> > > # to support UTF-8 output.
> > > USE_ICONV=0
> > > # PGSQL
> > > PGCONFIG=@PGCONFIG@
> @PGBEINCLUDES@/port/win32 @PGBEINCLUDES@/port/win32/arpa
> > > else
> > > PGFELIBS=@PGFELIBS@
> > > endif
> > > # Docbook
> > > XSLBASE=@XSLBASE@
> > > # Compilers
> > > CC=@CC@
> > > CXX=@CXX@
> > > # Other programs
> > > FLEX=@FLEX@
> > > YACC=@YACC@
> > > INSTALL=@INSTALL@ -c
> > > INSTALL_DATA=$(INSTALL) -m 644
> > > INSTALL_BIN=$(INSTALL) -m 755
> > > INSTALL_LIB=$(INSTALL) -m 755
> > > # PATHS
> > > prefix=@prefix@
> > > exec_prefix=@exec_prefix@
> > > bindir=@bindir@
> > > datadir=@datadir@
> > > mandir=@mandir@
> > > docdir=@docdir@
> > > libdir=@libdir@
> > > libexecdir=@libexecdir@
> > > MODULE_INSTALLDIR=@MODULE_INSTALLDIR@
> > > LPATH=@LPATH@
> > > # DLL
> > >  DLSUFFIX=.dll
> > >  DLFLAGS=@DLFLAGS@
> > > else
> > >  DLSUFFIX=@DLSUFFIX@
> > >  DLFLAGS=@DLFLAGS@
> > > endif
> > > # Use JTS instead of GEOS if available
> > > ifeq ($(USE_JTS),1)
> > >  USE_GEOS=0
> > > endif
> > > # Test the version string and set the USE_VERSION macro
> > > # appropriately.
> > > VERSION=$(shell $(PGCONFIG) --version)
> > > ifneq ($(findstring 7.1,$(VERSION)),)
> > >  USE_VERSION=71
> > > else
> > >  ifneq ($(findstring 7.2,$(VERSION)),)
> > >   USE_VERSION=72
> > >  else
> > >   ifneq ($(findstring 7.3,$(VERSION)),)
> > >    USE_VERSION=73
> > >   else
> > >    ifneq ($(findstring 7.4,$(VERSION)),)
> > >     USE_VERSION=74
> > >    else
> > >     USE_VERSION=80
> > >    endif
> > >   endif
> > >  endif
> > > endif
> postgis/lwgeom/Makefile ]===================================================
> > > include ../Makefile.config
> > > include ../Version.config
> > > # Default missing CXX variable to c++
> > > ifeq ($(CXX),)
> > >  CXX = c++
> > > endif
> > > NAME=lwgeom
> > > SHLIB           =
> > > SHLIB_LINK  =
> > > else
> > > SHLIB           =
> > > endif
> > > else
> > > endif
> > > override CFLAGS += -g -O2 -fexceptions
> > > override CFLAGS += -fPIC
> > > #override CFLAGS
> += -I$(srcdir) -DFRONTEND -DSYSCONFDIR='"$(sysconfdir)"'
> > > override CFLAGS += -DUSE_VERSION=$(USE_VERSION)
> > > override CFLAGS += -DPOSTGIS_LIB_VERSION='"$(POSTGIS_LIB_VERSION)"'
> > > override CFLAGS += -DPOSTGIS_SCRIPTS_VERSION='"$(SCRIPTS_VERSION)"'
> > > override CFLAGS += -DPOSTGIS_BUILD_DATE='"$(POSTGIS_BUILD_DATE)"'
> > > JTS_OBJ=lwgeom_nojts.o
> > > ifeq ($(USE_GEOS),1)
> > >  override CFLAGS += -I$(GEOS_DIR)/include -DUSE_GEOS
> > >  GEOS_RULES=detect_geos_version
> > >  GEOS_WRAPPER=lwgeom_geos_wrapper.o
> > >  JTS_OBJ=lwgeom_geos.o
> > >  SHLIB_LINK += -lstdc++ -L$(GEOS_DIR)/lib -lgeos
> > > endif
> > > ifeq ($(USE_JTS),1)
> > >  override CFLAGS += -I$(JTS_INCLUDES) -DUSE_JTS
> > >  JTS_WRAPPER=lwgeom_jts_wrapper.o
> > >  JTS_OBJ=lwgeom_jts.o
> > >  SHLIB_LINK += -lgcj -ljts -lstdc++ -L$(JTS_LIBDIR)
> > > endif
> > > ifeq ($(USE_PROJ),1)
> > >  override CFLAGS += -I$(PROJ_DIR)/include -DUSE_PROJ
> > >  SHLIB_LINK += -L$(PROJ_DIR)/lib -lproj
> > > endif
> > > override CFLAGS += $(PGBEINCLUDES) -DAUTOCACHE_BBOX=$(AUTOCACHE_BBOX)
> > > override CXXFLAGS := $(CFLAGS)
> > > # memory debug for gcc 2.91, 2.95, 3.0 and 3.1
> > > # for gcc >= 3.2.2 set GLIBCPP_FORCE_NEW at runtime instead
> > > #override CXXFLAGS += -D__USE_MALLOC
> > > # Add index selectivity to C flags
> > > ifeq ($(USE_STATS),1)
> > >  override CFLAGS += -DUSE_STATS
> > > endif
> > > SA_OBJS=measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o
> lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o
> $(GEOS_WRAPPER) $(JTS_WRAPPER) wktunparse.o lwgparse.o wktparse.tab.o
> lex.yy.o vsprintf.o
> > > OBJS=$(SA_OBJS) liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o
> lwgeom_ogc.o lwgeom_functions_analytic.o $(JTS_OBJ) lwgeom_inout.o
> lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o
> lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o
> lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
> lwgeom_triggers.o lwgeom_dump.o
> > > #OTHERS=y.output lex.yy.c wktparse.tab.c wktparse.tab.h lwpostgis.sql
> > > OTHERS=y.output lwpostgis.sql ../lwpostgis.sql postgis_geos_version.h
> > > # Makefile targets
> > > $(SHLIB): $(OBJS)
> > > else
> > > endif
> > >  mv -f y.tab.c wktparse.tab.c
> > >  mv -f y.tab.h wktparse.tab.h
> > > lex.yy.c: wktparse.lex wktparse.tab.c
> > >  $(FLEX) -Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
> > > lwgeom_jts_wrapper.o: lwgeom_jts_wrapper.cpp
> > > lwgeom_geos_wrapper.o: lwgeom_geos_wrapper.cpp
> > > lwgeom_geos.o: lwgeom_geos.c profile.h
> > > lwgeom_jts.o: lwgeom_jts.c profile.h
> > > lwgeom_nojts.o: lwgeom_nojts.c
> > > lwgeom_functions_basic.o: lwgeom_functions_basic.c profile.h
> > > # Shared library stuff
> > > ../lwpostgis.sql: lwpostgis.sql
> > >  cp lwpostgis.sql ..
> > > lwpostgis.sql: lwpostgis.sql.in
> > >  cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< | sed -e
> 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POSTGIS_VERS
> ION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POSTGIS_BUILD_DAT
> E@/$(POSTGIS_BUILD_DATE)/g' | grep -v '^#' > $@
> > > install: all install-lwgeom-lib install-lwgeom-scripts
> > > install-lwgeom-scripts:
> > >  @mkdir -p $(datadir)
> > >  $(INSTALL_DATA) lwpostgis.sql $(datadir)/lwpostgis.sql
> > >  $(INSTALL_DATA) ../spatial_ref_sys.sql $(datadir)/spatial_ref_sys.sql
> > > #- This has been copied from postgresql and adapted
> > > install-lwgeom-lib: $(SHLIB)
> > >  @mkdir -p $(MODULE_INSTALLDIR)
> > >  $(INSTALL_LIB) $< $(MODULE_INSTALLDIR)/$(SHLIB)
> > > ifneq ($(PORTNAME), win)
> > > ifneq ($(SHLIB), $(SHLIB_MAJOR))
> > >  cd $(MODULE_INSTALLDIR) && \
> > >  rm -f $(SHLIB_MAHOR) && \
> > >  ln -sf $(SHLIB) $(SHLIB_MAJOR)
> > > endif
> > > ifneq ($(SHLIB), lib$(NAME)$(DLSUFFIX))
> > >  rm -f $(SHLIB_BARE) && \
> > >  ln -sf $(SHLIB) $(SHLIB_BARE)
> > > endif
> > > endif # not win
> > > uninstall-lib:
> > >  rm -f $(MODULE_INSTALLDIR)/$(SHLIB)
> > >  rm -f $(MODULE_INSTALLDIR)/$(SHLIB_MAJOR)
> > >  rm -f $(MODULE_INSTALLDIR)/$(SHLIB_BARE)
> > > detect_geos_version:
> > >  sh ../geos_version.sh $(GEOS_DIR) > postgis_geos_version.h
> > > uninstall-lwgeom-scripts:
> > >  rm -f $(datadir)/postgis/lwpostgis.sql
> > >  rm -f $(datadir)/postgis/spatial_ref_sys.sql
> > > uninstall: uninstall-lib uninstall-lwgeom-scripts
> > > clean-lib:
> > >  rm -f $(SHLIB) $(SHLIB_MAJOR) $(SHLIB_BARE)
> > > clean distclean: clean-lib
> > >  rm -f *.o *.so *.a test $(OTHERS)
> > > maintainer-clean: clean
> > >  rm  -f lex.yy.c wktparse.tab.c wktparse.tab.h
> > > liblwgeom_sa.o: liblwgeom.c
> > >  $(CC) -DSTANDALONE -o $@ -c $<
> > > liblwgeom_sa.so: $(SA_OBJS) liblwgeom_sa.o
> > >  $(CC) -shared -o $@ $^
> > > liblwgeom_sa.a: $(SA_OBJS) liblwgeom_sa.o
> > >  $(AR) -rc $@ $^
> > > test: liblwgeom_sa.so liblwgeom_sa.a test.c
> > >  $(CC) -Wall -lm -g -o test test.c liblwgeom_sa.a
> > > tsort:
> > >  lorder $(SA_OBJS) | tsort
> > > ========================================[ postgis/loader/Makefile ]
> > > # PostGIS Loader Makefile
> > > SHELL = /bin/sh
> > > subdir = contrib/postgis/loader
> > > EXE =
> > > UNAME = $(shell uname)
> > > ifeq ($(findstring CYGWIN,$(UNAME)),CYGWIN)
> > >  EXE = .exe
> > > endif
> > > ifeq ($(findstring MINGW,$(UNAME)),MINGW)
> > >  EXE = .exe
> > > endif
> > > OBJS = shpopen.o dbfopen.o getopt.o
> > > ifeq ($(USE_ICONV),1)
> > >  override CFLAGS += -DUSE_ICONV
> > > endif
> > > override CFLAGS := -g -Wall -I.. $(CFLAGS) -DUSE_VERSION=$(USE_VERSION)
> > > all: shp2pgsql$(EXE) pgsql2shp$(EXE)
> > > pgsql2shp.o: pgsql2shp.c
> $(shell pg_config --libdir)/libpq.a -o $@
> > > else
> $(LDFLAGS) -o $@
> > > endif
> > > install: all
> > >  @mkdir -p $(bindir)
> > >  $(INSTALL_BIN) pgsql2shp$(EXE) $(bindir)/pgsql2shp$(EXE)
> > >  $(INSTALL_BIN) shp2pgsql$(EXE) $(bindir)/shp2pgsql$(EXE)
> > > uninstall:
> > >  rm -f $(bindir)/pgsql2shp$(EXE)
> > >  rm -f $(bindir)/shp2pgsql$(EXE)
> > > clean:
> > >  rm -f $(OBJS) shp2pgsql.o pgsql2shp.o shp2pgsql$(EXE) pgsql2shp$(EXE)
> > > TECHER Jean David
> > > 01MAP
> > > Tél: 04 67 45 60 27
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
