[postgis-devel] RE: pgxs
alex bodnaru alexbodn at 012.net.il
Tue Apr 26 10:36:46 PDT 2005
hi mark,
a few months ago i made a postgis installer for debian, with support for
any postgresql version supported by postgis.
the sole requirement from postgresql was the api include files, and the
current installed postgresql version is been determined with pg_config.
the making process also requires makefile.global, which provides some
files locations (i believe all are retrievable from pg_config), and
makefile.shlib, which mainly defines a few library building procedures.
this should probably be the contents of pgxs, and should probably be no
such big problem to make it work for older pg.
regards,
alex
On Tue, 2005-04-26 at 15:43 +0100, Mark Cave-Ayland wrote:
> Hi strk,
> > -----Original Message-----
> > From: strk at refractions.net [mailto:strk at refractions.net]
> > Sent: 26 April 2005 14:01
> > To: Mark Cave-Ayland (External)
> > Cc: 'Jean David TECHER'; 'PostGIS Development Discussion'
> > Subject: pgxs
> (cut)
> > You ironically asked me "Do you work for Microsoft" ?
> > I can bounce that question back to you ;)
> Lol :)
> > Making PostgreSQL upgrade a prerequisite for PostGIS upgrade
> > sounds a bit unfriendly... would disturb me in a production
> > environment.
> > In the long run we can leverage this behaviour, but I think
> > it is too early now. Pgsql 8.0 would be required and I'm not
> > sure about pgxs status in terms of "features". Have you
> > looked into it ? Does it give you enough abstraction to
> > really easy multiplaform builds ?
> > What we can consider in our efforts is "miming" the behaviour
> > of pgxs in terms of installation layout, to be compatible
> > when time come for a switch.
> I think I may have confused people here by the wording of my email; I was
> not suggesting that we force people to upgrade to PG 8.0 in order to run
> PostGIS. What I am trying it point out is that at the moment, everyone who
> has installed PostGIS must have a fully configured PG source tree available.
> So an upgrade compile would be as simple as downloading the new source in
> contrib/ then doing a make install.
> I agree that building PostGIS without the source is something we should
> definitely look at; however my concern is that I generally see quite a few
> tweaks to the linker flags going through the PG lists to tweak
> idiosynchrocies with particular platforms, and so I can see PostGIS always
> having to play catch-up everytime changes are made to the Makefile.
> So in brief, what I was suggesting was:
> 	1) Keep the existing --with-pgsql-src=/ptr/to/pgsql configure option
> for PG < 8.0.
> 	This would still require a configure'd source tree as we do at the
> moment,
> 	however everyone who uses PostGIS already has one ready and so I
> can't see this
> 	being too much of a problem.
> 	2) Add another --with-pgxs=/ptr/to/pg_config configure option for PG
> >= 8.0 which
> 	would allow PostGIS to build without a configure'd source tree.
> These two options
> 	are mutually exclusive.
> The compromise here was to not support building PostGIS *without* a
> configure'd source tree for PG versions < 8.0 in order to prevent us from
> having to maintain our own modified copies of Makefiles within the project
> (in particular to gain access to linker and compiler flags). The pgxs
> Makefile is an actual fact a modified version of the contrib/ Makefile and
> so building PostGIS shouldn't be a problem :)
> Kind regards,
> Mark.
> WebBased Ltd
> South West Technology Centre
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 791021
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
