[postgis-devel] Re: [HACKERS] GiST memory usage
strk at refractions.net strk at refractions.net
Tue Aug 16 04:28:57 PDT 2005
I've done a pass on memory usage in GiST indexing.
It doesn't seem we're really leaking, anyway, in the unlikely
event your tables are full of EMPTY or INFINITE geometries
the change should reduce memory usage.
I'll be interested in hearing from you Martin about box-only
version of the index. Does it still hit memory limits when
DETOASTED values are smaller ?
Teodor Sigaev (GiST developer) reports he's been able
to build rtree indexing on 1e9 records...
--strk;
On Sat, Aug 13, 2005 at 01:43:52PM +0200, strk at refractions.net wrote:
> Missing info for the report:
> 	win32
> 	postgresql 8.0.3
> 	maintenance_work_mem  512
> 	btree index on oid works fine
> --strk;
> On Sat, Aug 13, 2005 at 01:12:30PM +0200, strk at refractions.net wrote:
> > Hi all.
> > I've been reported memory limit hits
> > during a postgis index construction
> > (GiST index).
> > The indexed tuples are about 425 millions.
> > The index key is a box2d object (4*sizeof(float)).
> > The machine has 4 Gb of RAM, and operations are
> > peaked at ~2.4 Gb of usage.
> > Is there a way to detect where is memory hold ?
> > Is there an index-specific memory context for use
> > to early release memory blocks allocated during
> > operations (didn't see any use of memory contexts
> > in the contrib/rtree_gist) ?
> > TIA
> > --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
