[postgis-devel] NEW DYNPTARRAY type in lwgeom api
    strk at refractions.net
    Fri Dec  2 01:38:36 PST 2005
Another thing added to lwgeom api is
the "dynamic" pointarray.
There's no full support for such a type,
but it is a start and can be used to
construct pointarrays w/out knowing number
of points in advance.
You can:
	- create a dynamic pointarray
	  specifying dimension and
	  initial capacity
	- add a point to a pointarray
	  specifying wheter duplicates
	  are allowed
Missing:
	- destructor (get your pointarray and lwfree the rest)
	- points remover (points are still serialized, so
	  this is discouraged anyway)
	- memory reserving function
See liblwgeom.h for more info (search DYNPTARRAY).
Note that you will always add a POINT4D, use
of the setPoint4d() will abstract actual dimensions
used.
--strk;
 /"\    ASCII Ribbon Campaign
 \ /    Respect for open standards
  X     No HTML/RTF in email
 / \    No M$ Word docs in email
