[postgis-devel] Segfault with Intersects() in 1.0.6-CVS
Benj Carson benjcarson at digitaljunkies.ca
Fri Dec 2 19:20:07 PST 2005
Here are my full versions:
POSTGIS="1.0.4"
GEOS="2.1.4"
PROJ="Rel. 4.4.9, 29 Oct 2004"
USE_STATS
DBPROC="0.3.0"
RELPROC="0.3.0"
Debian currently has not packaged libgeos-2.2.0 yet.  If you think it will
help I can go and compile 2.2.0 however.
Thanks,
Benj
On December 2, 2005 06:44 pm, Paul Ramsey wrote:
> The key information here is your geos version, actually:
> select postgis_full_version();
> P
> On 2-Dec-05, at 4:20 PM, Benj Carson wrote:
> > Hello,
> > I am getting segfaults with PostGIS 1.0.6-CVS (updated as of
> > 2005-12-02) and
> > PostgreSQL 8.1 (from Debian) when calling Intersects():
> > # select intersects(
> >     polygonfromtext('POLYGON((0.0 0.0,1.0 0.0,1.0 1.0,1.0 0.0,0.0
> > 0.0))'),
> >     polygonfromtext('POLYGON((0.0 2.0,1.0 2.0,1.0 3.0,0.0 3.0,0.0
> > 2.0))')
> > server closed the connection unexpectedly
> >         This probably means the server terminated abnormally
> >         before or while processing the request.
> > Hopefully you are aware of this problem; if so please ignore me.
> > Otherwise,
> > I thought I should let you kind folks know.  Now, I know that CVS
> > code is
> > sometimes unstable, but I was using 1.0.5 but it was crashing on
> > ExteriorRing() for me, so I thought I'd see if 1.0.6-CVS had solved my
> > problem (it did), but I then ran into this...
> > Let me know if you need more info.
> > Thanks,
> > Benj Carson
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
