[postgis-devel] Segfault with Intersects() in 1.0.6-CVS
Carl Anderson carl.anderson at vadose.org
Fri Dec 2 19:44:03 PST 2005
Benj Carson wrote:
Benj,
I tried your test and got a FALSE, validly, back.
my env
select version();
 PostgreSQL 8.1.0 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 4.0.1
20050727 (Red Hat 4.0.1-5)
select postgis_full_version();
 POSTGIS="1.0.4" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.0" RELPROC="0.3.0"
Although some precision errors at very similar numeric values can still
be encountered your test example would never result in an error in a
working PostGIS version.
There must be a cross linked LIB or a Postgresql function stub pointing
to an earlier version.
I also note that
   postgis_full_version() returns version 1.0.4
you reference
   version 1.0.5
and
   version 1.0.6-CVS
hinting at version problems.
C.
>Here are my full versions:
>POSTGIS="1.0.4"
>GEOS="2.1.4"
>USE_STATS
>DBPROC="0.3.0"
>RELPROC="0.3.0"
>Debian currently has not packaged libgeos-2.2.0 yet.  If you think it will
>help I can go and compile 2.2.0 however.
>Thanks,
>Benj
>On December 2, 2005 06:44 pm, Paul Ramsey wrote:
>>The key information here is your geos version, actually:
>>P
>>On 2-Dec-05, at 4:20 PM, Benj Carson wrote:
>>>Hello,
>>>I am getting segfaults with PostGIS 1.0.6-CVS (updated as of
>>>2005-12-02) and
>>>PostgreSQL 8.1 (from Debian) when calling Intersects():
>>># select intersects(
>>>    polygonfromtext('POLYGON((0.0 0.0,1.0 0.0,1.0 1.0,1.0 0.0,0.0
>>>0.0))'),
>>>    polygonfromtext('POLYGON((0.0 2.0,1.0 2.0,1.0 3.0,0.0 3.0,0.0
>>>2.0))')
>>>server closed the connection unexpectedly
>>>        This probably means the server terminated abnormally
>>>        before or while processing the request.
>>>Hopefully you are aware of this problem; if so please ignore me.
>>>Otherwise,
>>>I thought I should let you kind folks know.  Now, I know that CVS
>>>code is
>>>sometimes unstable, but I was using 1.0.5 but it was crashing on
>>>ExteriorRing() for me, so I thought I'd see if 1.0.6-CVS had solved my
>>>problem (it did), but I then ran into this...
>>>Let me know if you need more info.
>>>Thanks,
>>>Benj Carson
>>>_______________________________________________
>>>postgis-devel mailing list
>>>postgis-devel at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
