[postgis-devel] Changes in regression test framework
strk at refractions.net strk at refractions.net
Wed Dec 14 03:03:40 PST 2005
On Wed, Dec 14, 2005 at 12:01:36PM +0100, Nicolas Ribot wrote:
> > -----8<-----------------------------------------------------------------
> > Creating spatial db postgis_reg
> >  PostgreSQL 8.0.0 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.4.3
> >  Postgis 1.1.0CVS - 2005-12-13 23:21:22
> >  GEOS 3.0.0-CAPI-1.0.1
> > Running tests
> >            regress: Ok.
> >      regress_index: Ok.
> >     lwgeom_regress: Ok.
> >        regress_lrs: Ok.
> >       regress_proj: Ok.
> >        removepoint: Failed (diff /tmp/regress_removepoint_diff_24464)
> >           setpoint: Ok.
> >        regress_ogc: Ok.
> >     regress_bdpoly: Ok.
> > Run tests: 9
> > Successful: 9
> > Failed: 0
> Is it normal to see 9 successful results. Shouldn't it be 8 + 1 failure ?
Ehm... my mistake, I actually copy-pasted the failing line after run,
the failing run really reports 8 + 1 failure
--strk;
