[postgis-devel] 1.1.0 closed - Release on 21 - call for tests
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Mon Dec 19 11:17:13 PST 2005
> -----Original Message-----
> From: strk at refractions.net [mailto:strk at refractions.net]
> Sent: 19 December 2005 10:40
> To: Mark Cave-Ayland
> Cc: Michael Fuhr; 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] 1.1.0 closed - Release on 21 - call for tests
> Thank you. Committed.
> Also:
> 	1. added 1.#INF => inf translation
> 	2. made use of a process-specific temporary file.
> 	3. used a consistent construct for out_and_err redirect
> 	4. added rule to make [eE][-+]0+[0-9]+ become e[-+][1-9]+
> 	   (required update of regress_expected as well)
> Tests (on Solaris particularly) welcome.
> --strk;
Hi strk,
I've just downloaded and tested the latest postgis-cvs.tar.gz - clean bill
of health for 1.1.0 CVS under MingW. Well done!
mca at IBM-SPARKS ~/postgis/postgis-cvs
$ make test
make -C lwgeom
make[1]: Entering directory `/home/mca/postgis/postgis-cvs/lwgeom'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/mca/postgis/postgis-cvs/lwgeom'
make -C regress test
make[1]: Entering directory `/home/mca/postgis/postgis-cvs/regress'
 PostgreSQL 8.1.0 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.2
(mingw                                             -special)
 Postgis 1.1.0
 - 2005-12-19 19:03:59
   GEOS: 2.2.1-CAPI-1.0.1
   JTS:
   PROJ: Rel. 4.4.9, 29 Oct 2004
Running tests
           regress: Ok.
     regress_index: Ok.
    lwgeom_regress: Ok.
       regress_lrs: Ok.
       removepoint: Ok.
          setpoint: Ok.
       regress_ogc: Ok.
    regress_bdpoly: Ok.
      regress_proj: Ok.
Run tests: 9
Successful: 9
Failed: 0
make[1]: Leaving directory `/home/mca/postgis/postgis-cvs/regress'
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
