[postgis-devel] 1.1.0 closed - Release on 21 - call for tests
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Dec 21 02:08:29 PST 2005
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of strk at refractions.net
> Sent: 20 December 2005 09:22
> To: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] 1.1.0 closed - Release on 21 - call for tests
> On Mon, Dec 19, 2005 at 06:11:59PM -0700, Michael Fuhr wrote:
> > This works on FreeBSD 6.0, Solaris 9, and an old Linux box I have
> > access to:
> > sed 's/[eE]\([+-]\)0\{1,\}\([0-9]\{1,\}\)/e\1\2/g'
> Thank you !
>  I hope Mark can test on MingW before tomorrow.
> --strk;
Hi strk,
I've just downloaded the latest postgis-cvs.tar.gz and run the regression
tests - everything passes under MingW.
$ make test
make -C regress test
make[1]: Entering directory `/home/mca/postgis/postgis-cvs/regress'
 PostgreSQL 8.1.0 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.2
(mingw                                             -special)
 Postgis 1.1.0
 - 2005-12-21 10:04:56
   GEOS: 2.2.1-CAPI-1.0.1
   JTS:
   PROJ: Rel. 4.4.9, 29 Oct 2004
Running tests
           regress: Ok.
     regress_index: Ok.
    lwgeom_regress: Ok.
       regress_lrs: Ok.
       removepoint: Ok.
          setpoint: Ok.
       regress_ogc: Ok.
    regress_bdpoly: Ok.
      regress_proj: Ok.
Run tests: 9
Successful: 9
Failed: 0
make[1]: Leaving directory `/home/mca/postgis/postgis-cvs/regress'
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
